Recommended tire pressure?
Hi Everyone, I'm getting ready for my first DE tomorrow. My '95 has 18 inch turbo look wheels and Bridgestone Potenza RE750's, 265/35 R18 93W in the rear and 225/55 88W in the front .
What is the recommended pressure for these tires for a car control clinic and autocross event? The door sticker lists 36 psi but that is for 17 inch wheels.
Outside temperature should be in the high 40's in the morning, warming up to 65 mid day.
Thanks for your help!
Since this is your first DE and with these cold temps, I dont think you are going to generate too much heat on them. I would advise to start 32 front and 34 rear and take it from there. After your first session drop off your instructor quickly
and then get out of the car and check the pressures. For sure you want to be below 40psi HOT. I would blead to be around 34-36 HOT after the sessions that will follow. Its all going to be relevant to the heat you are going to generate on them with these cold temps.
Have fun! I'm envious!
Addict & Guru
Danny's advice is right on - as usual.
I'd add that you should defer to your instructor. DO NOT make any pressure changes without informing & getting the approval of your instructor. For your 1st DE, don't obsess about tire pressures.
Phlat Black Guru
Lifetime Member
- Times 2
Lifetime Member
- Times 2
1 Post
Check ego at track entrance.........pick it up when you leave,
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
