Track Dawg Project Update #2
Thought I'd share an update of my track dawg project.
Since passing Smog, I've been focused on collecting parts and starting real work. So far, I've sourced seats, shocks, steering wheel, shift ****, RS shifter, and lots of other odds and ends.
I painted the rear bumperettes:
Started to clean the suspension in preparation to install the KMS/Penske racing shocks (I hate cosmoline):
Installed WEVO Semi-Solid Motor Mounts:
And today's project, installing RS Door Panels from AppBiz:
Which gave me an opportunity to remove the sound deadening from inside the door, and debate having speakers. I'm thinking removable speaker boxes...
Next on the agenda is to remove the interior and temporarily install the RS carpet set. Temporarily in the sense I need to source a roll bar or roll cage and install.
Thanks!
Don
![](http://www.plumley.org/porsche/photos/rear_w_bumperettes.jpg)
![](http://www.plumley.org/porsche/photos/rr_wheel_well_cleaning.jpg)
![](http://www.plumley.org/porsche/photos/wevo_motor_mount.jpg)
![](http://www.plumley.org/porsche/photos/r_rs_door_panel.jpg)
Thanks!
Don
Don, could you tell us more about how you painted the rear bumperettes? How did you prep them and did you use standard paint? I've been thinking about whether to do it diy or buying the bumperplug ones.
If this were a street car, I'd use some products right from the car paint supply store - flexible bumper prep, flexible primer and SEM flexible paint. They have gloss white and it is close enough. If you have a tough color, there are a number of places that will mix you a custom color that should stand up well enough with the right prep. I don't remember how much Bumperplugs.com charge for this (I also made plugs for my front bumper), but I enjoy doing it myself.
