993 Forum 1995-1998
Real Power Gain, or Real BS?
Old 01-16-2006, 10:01 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
chris walrod's Avatar
Originally Posted by cabrio993
LOL...
Whoever wrote this is probably the same marketing guy that works for Fabspeed.
You can say that again
There is always a compromise somewhere. Nobody gets something for nothing. Power and economy increase. Sign me up!!
Old 01-16-2006, 10:29 PM
milrad
PS Armorer
milrad's Avatar
If this is true, then Porsche should fire their engineers and hire this guy. 10% gain for $50? Pure, undiluted BS.
Jason
Old 01-16-2006, 10:36 PM
autobonrun
autobonrun's Avatar
Default Only applies if something is already wrong.
Assuming the wires in a car are the correct size so there is no voltage loss in the wiring, and assuming there are no cuts in the insulation where the voltage is jumping to ground, then the maximum available voltage and current will be available at the plug tip. I further assume that the Porsche engineers designed the cables to be the correct size. Therefore, the grounding issue as far as increased HP, is total BS. Just what you guys said.
However, if someone has undersized aftermarket and/or cracked insulation plug wires, then just replacing them with new stock plug wires will provide the same benefits this guy claims.
Old 01-16-2006, 10:48 PM
Bull
Bull's Avatar
Some of you guys are missing a key part of the original post/claim. Not only is it a 10% power gain for $50 and an improvement in fuel consumption, "the mod actually increases the life of the engine..."!
Group buy???????
Old 01-16-2006, 10:56 PM
cabrio993
cabrio993's Avatar
Group buy???????
Maybe...I'll e-mail him and ask him if it also eliminates clogged SAI ports. This could be the holy grail of all mods by far!
Old 01-16-2006, 11:11 PM
CP
CP's Avatar
Wow,
May be it will cure cancer as well.
CP
Old 01-16-2006, 11:19 PM
Red rooster
Red rooster's Avatar
Fantastic !!!!!!!!!! Best laugh Ive had all week !!!!!!!!!
Geoff
Old 01-16-2006, 11:55 PM
autobonrun
autobonrun's Avatar
Group buy???????
I believe the last part. You put it in, your car won't start, and voila your engine life gets extended.
Old 01-17-2006, 12:16 AM
ARM993
ARM993's Avatar
I'll take a set for each of my cars. Amazing what some people will spend money on. Wow, if you buy these wires, a K&N filter, Fabspeed mufflers, and chip the car your 993 should be pushing 325hp.
Old 01-17-2006, 01:31 AM
Bull
Bull's Avatar
If you simply think about doing those mods, you get the same 325hp!
Old 01-17-2006, 05:42 AM
eloyex
eloyex's Avatar
uhmmm ...
smell like BS ...
taste to BS ...
looks like BS ....
texture and chemical analysis shows BS
so .. IT IS BS !!!!!!!!!!!!!!!!!!!!!!!!!!
Old 01-17-2006, 03:01 PM
trojanman
trojanman's Avatar
bovine scathology...
Old 01-17-2006, 11:30 PM
Scott 1996 993c2
Scott 1996 993c2's Avatar
Bull ****
Scott
Old 01-18-2006, 02:17 PM
Trader220
Trader220's Avatar
I believe Motor Miester sells this kit for 100 bucks and they'll install it for 300.
Old 01-18-2006, 02:29 PM
Tonydec
Tonydec's Avatar
Is he also indexing the spark plugs? That's an old racing trick thats supossed to maximize the spark location and combustion.
As for grounding, it does work in specific applications. On my M/C, there are lots of interruptions in the power supply and grounds to the coils, connectors, etc. A common mod is to re-wire with direct connections. Quicker starts, less plug fouling, etc. Don't claim that it gains power, but it is better reliabilty.
Quick Reply: Real Power Gain, or Real BS?
