993 Forum 1995-1998
Did I damage a lifter??
Old Jan 10, 2006 | 11:13 PM
Porscheologist's Avatar
Porscheologist
Default Did I damage a lifter??
When I did my recent clutch job I lost some oil when I removed the lower oil line. I estimated about 2 quarts. So I put two quarts of oil back into the car before I started her up and took her out for a 45 min test drive. My oil pressure was fine the whole time with no warning lights etc. When I got back the oil level was not registering on the gauge. I checked the dipstick and it appeared to be in the middle of the twisted part. Turns out that I had to add 4 more quarts to get the oil level back were it had to be so I must have misread that stupid dip stick! I was driving around with only 8 quarts of oil!!!
Now I am totally freaked out because yesterday I noticed tapping sound coming from my lower (exhaust?) drivers side engine bank. The car drives smooth and the sound is not terribly loud. It does not get louder with rpms and is a constant "sewing machine sound" that is slightly louder on one side. Should I worry about it? Maybe I'm being paranoid but the sound "seems" louder than before. Your input is greatly appreciated!!
Old Jan 10, 2006 | 11:26 PM
chris walrod's Avatar
chris walrod
Guru
Rennlist Small
Business Sponsor
Give it a little time. Get the car good and warm and note any changes. Worse comes worse, you'll have to change a few of them. No worries. They are easy to change and can be done with the engine in the car.
Old Jan 10, 2006 | 11:29 PM
Porscheologist
Are lifters expensive? What about other things that could have been damaged like valve guides or worst? Thanks Chris for your quick response as usual.
Old Jan 10, 2006 | 11:30 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
The lifter prices seem to range from $38 to $75. I bought 6 from Pelican last year. Check 'em out..
Old Jan 10, 2006 | 11:50 PM
Leland Pate's Avatar
Leland Pate
Are you absolutely sure you checked the oil properly? Warm engine at idle? If you already know this I appologize, but I made this mistake with my first 911 and over-filled my tank by about three quarts.
Plus, I'd think you'd get an oil pressure warning light on the dash if you were so low on oil that the pump went dry momentarily.
Drive it for a while and see if the ticking is still there.
Old Jan 10, 2006 | 11:52 PM
AOW162435's Avatar
AOW162435
Seared
Exhaust leak?
Andreas
Old Jan 11, 2006 | 01:06 AM
Air Kuul TT's Avatar
Air Kuul TT
lee,
nice avatar!! :-)
Old Jan 11, 2006 | 02:54 AM
Steve Weiner-Rennsport Systems's Avatar
RL Technical Advisor
Hi:
Driving around with 8 qts in the system will do no harm unless you are racing,.... I'd always advise anyone to completely warm the engine and check the oil on the dipstick before doing anything after a service, but you didn't hurt a thing.
Assuming that you put in the correct viscosity oil (15w-50), you can check for noisy lifters using either a mechanic's stethoscope or a long screwdriver. Place the tip of the stethoscope or screwdriver (putting your ear on the end of the handle) on each valve cover and take a listen while the engine idles. You will hear all kinds of mechanical sounds, but lifter noise is distinctive with its hard rapping.
Old Jan 11, 2006 | 03:43 AM
grmnxtc's Avatar
grmnxtc
Steve......this type of noise?
Old Jan 11, 2006 | 10:57 AM
chris walrod
Guru
Rennlist Small
Business Sponsor
Old Jan 11, 2006 | 11:43 AM
TheOtherEric's Avatar
TheOtherEric
As a side note, now you know why I don't take my oil level too seriously. In a 12-qt dry sump system, being low a quart or so is just no big deal. I know that sounds like heresy, but really, we gots plenty of oil in there.
Old Jan 11, 2006 | 12:47 PM
LOL,...O-M-G,..thats FAR worse,...
Old Jan 11, 2006 | 02:03 PM
Ray Calvo's Avatar
Ray Calvo
Passed On
If oil temp and pressure were OK during this time, and this 45 minute test drive didn't involve something like qualifying for Le Mans or Daytona 24 Hours, then I wouldn't think you would have damaged the engine. Give it a couple of days and see what happens.
(You say it's a "constant" ticking - does that mean it does NOT vary with RPM? If it doesn't, then hard to see how it could be a lifter).
Old Jan 11, 2006 | 02:08 PM
AOW162435's Avatar
AOW162435
Seared
Agree. That's why I suggested a possible exhaust leak earlier. Was the exhaust removed or dismantled during the clutch change?
Andreas
Old Jan 11, 2006 | 04:04 PM
Porscheologist
thanks for the input guys. The slight ticking sound has quited some. It's still there and I guess always has been. I think that once I realized my goof any and all noises were "Amplified" in my pee brain. It's not getting worst and the car runs very smooth. As I accelerate the sound goes away. I can only hear it if I roll down a window and listen for it. We shall see but hopefully I got away with a bone head move. Exhaust? Could be but I did not take that appart (I did remove the mufflers). The other issue I have I is when down shifting from first to second I get an occasional nick. I never did before. I will post a seperate thread on this. Thanks again!
