battery tender
I tried a couple searches in the archives to see if this was discussed at length, but I couldn't track any down.
Perhaps someone can pipe up and give us a brief explanation.
My question is if it's safe to use the porshce charge-o-mat on other cars, or is it engineered specifically for the 911s? (i.e. spec of voltage/ amps to be considered fully charged and turn the maintainer off)? Also, I wonder if all cars can use the cigarette lighter method to keep a charge, or do only certain newer cars have this option (do older cars keep a link to the cigarette lighter when the car is turned off to allow a plug-in maintainer to work)?
PJC
One terminal goes to each battery post leaving a little pigtail which can be tucked away when not needed. The business end of the Battery Minder is zip tied to an electrical outlet to prevent anyone from tripping on the wire. Simple and effective.
The problem with the BMW/Porsche branded Battery Tender is that some models (as in the cars) switch off the 12V accessory outlet after a few seconds. This would render the cigar lighter plug charger useless. So hardwiring should be the only method employed and can be done by anyone with zero mechanical ability.
As for winter storage, the suspension should not be left unloaded. It's not its natural state and can lead to premature dampener failure (from my limited research). Lifting the car is a good idea to isolate the tyres from the ground temp., however blocks of wood should be placed between the tyres and the ground to preload the suspension. Dudley's sizzor lift is perfect but the car should be lowered so the tyres aren't just hanging in mid air. Oh and set the tyres to sidewall-max + 10% (fudge factor). Sidewall-max is the [tyre] manufacturers guidline given a normal day allowing for a driven car. Since we're talking about storing the cars for winter, not only is the ambient temp low, but the cars won't be driven. That's my unscientific fudge factor explanation.
As for petrol, back in the day, filling the tank was recommended to reduce the change of moisture/corrosion/etc. However, times have changed. Petrol tanks are generally made from plastic (certainly the case in a 993) and fuels are more stable (less prone to to deteriorate(sp?)). STA-BIL is a good idea though.
Rodents!
These rat b'stards (pun intendend) seek out nice cars sitting in garages. They have monthly meetings and have GPS (remember how times have changed?). They found my M Coupe this year but no damage done. A trip to Home Depot got me a box of moth ***** for less than $2. Never put them in the car. Not even under the bonnet. Instead, place some in ceramic bowls around the car/garage.
Of course there are lots of other little tips to prep your car for winter such as Wurth door moulding conditioner, waxing the car, conditioning the leather, change of oil prior to hibernation, etc., but all that info can be had by doing a search on the topic. I think an excellent resource is Larry Reynolds (from the link posted above). He has all the products mentioned including Porsche branded ****e.
Disclaimer - I'm in no way affiliated with CCS. Just thought I'd pass on some useful info.
I just soldered on the RS lead.
I bought a used Schumacher smart charger on ebay and it maintains at 13.5V just great. There's no point to owning a separate maintainer since good chargers already have that feature.
I checked the unit, just to be sure, and it is only 1.5 Amps. I also checked my receipt. I paid $31.49 (with tax) on Jan 8, 2005. I have had it plugged in continuously since I bought it with no ill effects (except for the time it was switched to 6V and it allowed the battery to discharge).
I bought it at Sears because I had a gift card and it seemed to fit my needs. I am sure there are better/fancier maintainers on the market.
Here it is:
http://www.sears.com/sr/javasr/produ...00&tab=des#tab
In fact, I would not be surprised, if you peeled off the Sears sticker, that this charger is actually a Schumacher charger.
Funny, just adding the Sears sticker bumps the price up $11.
(I corrected the website to avoid having anyone else buy the wrong model.)
http://www.acehardware.com/product/i...ductId=1296395
Hooked up the maintainer and can sleep better now.Andreas
Gotcha. It looked a little bigger than just 1.5 amps.
And yup, it looks exaclty like the Schumacher unit. Schumi makes their larger DieHard chargers so it's no surprise that they supply the little maintainer too. Andreas- You didn't mention it, but I hope you hooked up your battery drain tube. Trust me, they are needed.
The Interstate battery has an oval-shaped port. I've already contacted them to see about a supposed "vent kit" for the MTP-91. In the meantime, I will fashion a connector to work with the stock hose.
Andreas
I'd go back to the dealer for the vent kit. Or call IBSA directly. http://www.ibsa.com
Here it is:
http://www.absolutehome.com/web/cata...aspx?pid=65174
Dudley, are you still leaving yours plug in continuously? Have you had any problems? I assume that since it is only a 1.5 AMP charger then you are safe it leave it plugged in?
Thanks!
Christian
