Ride Height on Front, MO30 with Bilstein HD w/ 30mm More Thread
I recently installed a set of Bilstein HD's with 30mm more thread on the front shocks. Car rides like a dream with the new shocks installed.
Due to the lower front ride-height, I find the car oversteering a lot more than I really like and would like to correct this situation.
Anyone has any experience with similar suspension set-up and can offer advice on the ideal ride height for the front?
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
congrats on your new suspension! What ride heights do you have currently? I presume you had your car aligned after the install. Is there a print out to what the car was aligned to? What springs did you use?
Did you chance sway bars also?
There are a number of ways to change the balance of the car to you liking. Post more info about your car and hopefully you can get it sorted..
I have Mo30 springs on the car, and the alignment was done at the dealer's to the specs stated for the Mo30 suspension. I am located in Singapore, and it has been a challenge trying to get the printout from the alignment check from the dealer, which is the frustrating part that has caused me to post here...
