help for reinstalling tach
This should be simple, right? I got the tach out and replaced the bulb but can't get it back in. Started to take apart the plastic housing which covers the stalks and removed everything I can find but something is still holding the two halves together. They are loose but won't come off. I'm not sure that I even need to get the housing off but it seemed like a good idea at the time. Suggestions?
You can do it with the housing loose. BTW, there's also two screws behind the steering wheel so you need to turn it right & left to get them out. It also helps if you remove the oil temp & level gauge as it is much easier to slide the tach into position. Then invert the tach to get it started in the hole as the rear is smaller at the bottom, then rotate to the correct position.
Hope this helps...
Hope this helps...
I have already removed the screws behind the steering wheel but something else is holding the housing together. I'll definitely try the rotation trick. I can't see how removing another gauge will help - it doesn't seem to be in the way. Am I missing something?
Seared
Terry,
I have not checked under the steering column of my 993, but on many cars there is a column hanger/bearing right under the dash. If a bracket of this sort is loosened or disconnected, the column can typically drop down to allow access to the instrument cluster.
Andreas
Andreas
Originally Posted by pcar964
Don't forget to install the tach rotated with redline at 12 o'clock position - makes for much better visibility, especially for track use!!!
thinkin' the same. only w/o the track in mind.
btw: just had a new tach installed & the did pull the wheel to do it.
curious. was this done for ease of replacement???
weird though... noticed the new one has a very "day-glo" orange needle compared to the older gauges. oh well
Thanks to all. The trick is indeed to rotate the tach 180 degrees, after which it goes in pretty easily. Of, course, nothing is that simple - I slightly bent the rim of the tach and one of the four screws holding the housing together won't engage. But we do this for fun, right?
