993 Forum 1995-1998
Do you shift into neutral while waiting at stop lights?
Old 12-10-2005, 12:20 PM
Bull
Bull's Avatar
Originally Posted by Rob 97 993c2
Dont know if this is accurate, but my shop told me when putting the car in gear to:
"go from neutral to second and then straight into first, so, N-2-1. This will release the synchros in a better way"
Is this correct?
Is this a variation on the 5 to 1 listed above by Steve?
Same idea, except you are putting wear on the 2nd gear syncro instead of the 5th gear syncro. The 2nd gear syncro is usually the most used and often the first to go bad in a gear box, so I wouldn't choose that gear.
Old 12-10-2005, 12:31 PM
TomF
TomF's Avatar
I will try the 5th gear trick too. Thanks for the suggestion.
Old 12-10-2005, 12:37 PM
Caveman
Caveman's Avatar
Bit of both, if we are talking a baout a few seconds then keep in gear with foot dpressed; if longer wait then into neutral, clutch pedal released.
Old 12-10-2005, 01:48 PM
DarrylH
DarrylH's Avatar
This discussion is useful...
Old 12-10-2005, 02:38 PM
mborkow
mborkow's Avatar
always
Old 12-10-2005, 05:11 PM
leeham
leeham's Avatar
Default Shift out of gear without clutch?
I have a friend who has about 240K on the original clutch in his Saturn - not a lot like a 911, I know, but here's the trick: He shifts out of gear while coming up to a traffic light without depressing the clutch. He lets it get to about 1000 RPM then just pushes it out of gear. So, suppose I'm approaching a red light in 3rd and know I will have to stop. Do you think this technique would lengthen th 911's clutch life?
Always learning,
LeeH
Old 12-10-2005, 05:45 PM
kkim
kkim's Avatar
I don't know if that will lengthen the life in a 993, but that is the same procedure I do if I can coast into a stop. Take it out of gear and coast into a stop using the brakes. In all the vehicles I have owned, I have never had to change out a clutch except in a truck @ 150k miles... and I think the major wear occurred due to it being my son's vehicle for a few years when he first got his licence. Darn kids!!
Old 12-10-2005, 05:54 PM
ca993twin
ca993twin's Avatar
Bull is absolutely correct... 2nd gear synchro is THE most important synchro in your trans, Take care of it.
I can't see any beneficial result from popping into neutral before coming to a stop (with or without using the clutch) except to increase your brake wear. It is not a signficant factor in clutch wear.
Old 12-10-2005, 05:58 PM
Tom W
Tom W's Avatar
I'm contrarian. I put it in neutral if it will be a long wait. For a short stop, I don't bother. I've been driving this way for over 30 years and have never had an issue with a throw-out bearing on any of my cars. I've put 47,000 miles on the 993 driving it this way too (without issue).
Old 12-10-2005, 06:41 PM
Bull
Bull's Avatar
Just to be clear, what Tom W describes here is what I do....subject to each person's definition of "a short stop". Most of my traffic controlled stops are on well known routes, and I have developed some good ideas of the likely length of those stops even where I can't see the amber light for the intersecting traffic.
When I was 19 years old and riding a motorcycle (yes, they had internal combustion engines back then!), I witnessed a young guy sitting at an intersection, reving his bike engine (we were both on Triumphs), when the clutch cable snapped and he shot out into the intersection. He lived, minus one leg. That stays with you a long time when you think about neutral at lights. Of course, it isn't likely with an idling engine in a car........
Old 12-10-2005, 06:46 PM
Sonic dB
Sonic dB's Avatar
I always put it in neutral and foot of the clutch at lights...or in heavy LA traffic. Sometimes I catch myself with my hand on the shift **** too long and remember to remove it.
The shift in to another gear first is an old 915 trick and is something that really helps on my 86 Carrera, I havent tried it on the 993 yet cause there seems to be no need to do so.
Old 12-10-2005, 07:38 PM
cooz
cooz's Avatar
yes
Old 12-10-2005, 09:21 PM
David 23
David 23's Avatar
Totally agree.
Old 12-10-2005, 10:25 PM
Rob 97 993c2
Rob 97 993c2's Avatar
Why would you shift to neutral withOUT pressing the clutch? Is this bad? i always thought you should clutch-in anytime you move the shifter. pls correct me if im wrong
Old 12-10-2005, 10:47 PM
kkim
kkim's Avatar
When I was riding sport bikes, I always left the bike in gear at stop lights and constantly scanned the rear view mirrors for fast approaching cars that don't see you. It at least gives you a chance to get out of their way if you think you're going to be rear ended. With the bike in neutral, it takes too long to get it back in gear to get out of the way. It happens more often than you would think.
Quick Reply: Do you shift into neutral while waiting at stop lights?
