993 Forum 1995-1998
immobilised!
Old Nov 22, 2005 | 03:37 AM
indian porker's Avatar
indian porker
Default immobilised!
guys, anyone with a '95 european model 993 with separate engine & immobiliser keys, you've got to help. What do you do if the immobiliser fails and makes the ignition inoperative? i.e., normal procedure for starting the car is immobiliser key insert into dashboard slot, remove, immobiliser beeps to confirm deactivation, insert engine key into ignition, crank and presto! NOW, AS OF YESTERDAY, insert immobiliser key, no beep , insert engine key an dcrank,, NO CRANK. All other pre-ignition electricals fine such as warning light, oil cooler fan ( mine is to set to run always ).
Checked the FAQ's, nothing on this.
From a desperate man whose car has banished him from using her!!!
Old Nov 22, 2005 | 07:57 AM
Felix's Avatar
Felix
Rennlist Lifetime Member
Is this a UK car?
Old Nov 22, 2005 | 09:22 AM
AOW162435's Avatar
AOW162435
Seared
Have you ever replaced the key fob battery?
Andreas
Old Nov 22, 2005 | 01:09 PM
indian porker
Yes, this is a UK supplied car but currrently in India. Have replaced the key fob battery ( a while ago ) but this engine key only has a built-in light. The immobiliser key is separate.
Old Nov 22, 2005 | 01:14 PM
Felix's Avatar
Felix
Sounds like a PA-1000 or PA-2000 system that was specific to the UK market. Try contacting the original manufacturer, Hamilton and Palmer, http://www.hamilton-palmer.co.uk/
Old Nov 22, 2005 | 02:17 PM
indian porker
Thanks, will do. Do you think its definitely the immobilizer? Starter motor perhaps? Are they known to just stop without prior warnings? I remember a while ago my rear wing brake light had failed which did not allow me to start the car...could it be something else this simple?
Thanks for your help.
Old Nov 22, 2005 | 05:58 PM
Felix's Avatar
Felix
Isn't there an LED that indicates the state of the immobiliser? Has its behaviour changed?
How on earth did that affect the ability to start the car?
Old Nov 23, 2005 | 03:06 AM
indian porker
No specific LED for the immobilizer other than the door top LED's which are blinking twice. I could not find any grounding wires of either the stereo or the green alarm wire for the stereo grounded anywhere behind the cage as suggested in another earlier thread. The immobilizer has a separate key which after inserting into a specific dash slot, emits a beep which confirms de-activation. This actually stopped a few months ago but the car always started after inserting the immobilizer key.
The rear wing has a break light, the wire of which had shorted while fixing the wing. This caused the car to not allow engagement out of P gear on the tiptronic ( sorry, it did not mean the car did not start, should have been clearer ).
Old Nov 23, 2005 | 07:10 AM
GabiOsz's Avatar
GabiOsz
I have had this problem; it seemed that the contacts on the "chip/key/thing" had worn down through years of pushing it into the dash. With the contacts work down it wasn't being read properly, I used the spare which was like new and it was ok.
The replacement chip-thing was about £20 from the OPC.
Hope it helps.
Incidentally, quite separately my beeper stopped working for some unknown reason, but you should still hear a click, which I think comes from the DME under the passengers seat, when the immobilizer disengages.
Old Nov 23, 2005 | 07:34 AM
SJB993's Avatar
SJB993
Hi Gabi,
The casings on both my "key/chip/things" for the immobiliser have been cracked by the previous owner, and so both are held together with sticky tape. When you got you new one, did the OPC program it for you?
Old Nov 23, 2005 | 07:38 AM
GabiOsz's Avatar
GabiOsz
They took mine off me took for a minute or two, I'm not sure what they did, they must have read it somehow, and them ordered me another one within a day or two. I assume that, like the door locks, a chasis number will give porsche enough info to make you another.
Old Nov 24, 2005 | 07:32 AM
indian porker
Hi Gabi,
Tried that already ; my car's first owner had lost the second set so had two new chips made immediately last year by an OPC and they are still like new. You're absolutely right - you can hear a slight click so maybe its the starter motor. Do you know where it is? Is there anything else to check for starting? Has a new DME relay just installed a few weeks ago.
Old Nov 24, 2005 | 08:01 AM
GabiOsz's Avatar
GabiOsz
I'm not sure where the starter motor is, someone else will have to chime in on that one, but from what I've experienced in my car the click is the drive block disengaging.
Old Nov 24, 2005 | 08:20 AM
indian porker
Is you click the same as it always was? I may be imagining this but my click ( after the beep stopped a while ago ) is not as noticeable as it was. Perhaps the drive block is not disengaging.
Old Nov 24, 2005 | 08:44 AM
GabiOsz's Avatar
GabiOsz
I have posted on the other thread, but it may be worth checking the wires on the bottom of the fuse box board. Mine came loose a while ago and the car was misfiring and konking out, it may be that. Also get another DME relay to keep as a spare and try that, it may be that your new DME relay is defective in some way.
If you were experienceing eratic starting behaviour previously, then it seems to me more likely that it is not the drive block. Especially if you are hearing the click, I could be wrong but check just in case. I am not sure how or why the beep started working again, my garage did a lot of work and had the engine out for another reason, when they had finished the beep was working again.
