Transmission Seal Leak
![Thumbs down](https://rennlist.com/forums/images/icons/icon13.gif)
After 2 days at Infineon I drove the 993 back to LA. Car ran great at the track and all the way home.
The next morning I found the pool of oil under the engine tray show in the pic. The shop determined that the oil was coming from the transmission seal. The LWF/Clutch install only has 18k miles.
I may just have a new clutch put in as the tranny will have to come out for the new seal and I don't trust the install. The hydraulic line to the clutch had a loop in it which we already fixed. I think the guy who did the work on this car was an idiot.
Good thing that you documented the oil leak with the pic. That can help a lot to determine what kind of a leak you have.
Any chance you could take a picture of the underneath of the car? That would help even more.
Didn't get any pictures underneath. The engine tray had to come off to see the oil around the front seal (flywheel seal?). The pool of oil was where the oil was collecting and draining from the engine tray, so that wasn't very informative.
The car is at the shop now. They wouldn't let me drive it home
Technical Guru
![](http://members.rennlist.com/jandreas/RMS.jpg)
and the front main seal is on the fan side
![](http://members.rennlist.com/jandreas/FMS-Overview.jpg)
Originally Posted by vjd3
is there a way to differentiate gear oil from engine oil?
Got my car back today, quick turnaround. Clutch was OK; they replaced a few minor parts.
Most of the $1,800(OUCH) total was labor. That's gonna set back my upgrade plans a bit.
The clutch feels better now. Shifting is a little smoother and I no longer have a problem getting out of gear under load. Looks like there had been a problem for a while and track driving brought it out.
$1800 for a C2?? Well I guess if you want to charge up the labor bill by spending an extra few hours by dropping the motor, and then do an alignment because you removed the suspension cross member to drop the engine then I can see how you get it that figure. Last C2 LWF kit I did took about 5 hours, and that included doing the RMS.
