Electrical Gremlin
Sat. morning the car started fine. On the way to our once a month car guy hangout I found that the sunroof, windows, mirrors, wipers and fan were inop. Checked fuses- none blown. All other electrical items OK. On the way home a few hours later everything suddenly started working.
Is there a common relay for all these components?
There is no common relay for all those. R21 for the SR and R22 for the windows. The numbers are marked on the inside of the relay/fuse lid. I would pull each relay out, clean and dry the contacts, then reseat each. I thought my WS washer relay was out, did the above and it worked again.
