Pedal Assembly Lubricant - What To Use?
I'm planning on replacing my clutch master & slave this weekend and figure a good cleaning & lube of the pedal assembly would be wise. What's the best type of grease and/or spray to use? I've searched the posts and p-car.com, but a specific lubricant was not mentioned.
On my 73 911, I used the recommended white lithium grease on the pedal assembly (brass bushings)
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
STP white lithium grease in a spray can. Sprays thin, seeps into 'things' then thickens-up a few minutes later. Great for door hinges and latch assemblies. Throttle linkages, pedal assemblies. Works great!
