LWF and Clutch - 5 hours of labor
Upon reading good feedback from a Rennlist member about John's Foreign Service in Laguna Niguel, CA, I had Russ replace my clutch and install a LWF.
Not counting a wrong shaft tube that was delivered, it took Russ only 5 hours to do the job. No engine removal and no issues regarding idling. Clutch is light as a Honda now and although not as a drastic difference as expected, the engine does spool up faster.
Verdict? LWF recommended and if you're nearby, definitely call up Russ.
Lifetime Member
Lifetime Member
Hey, nice looking cars guys. We should have a Arena Red section at the next Orange Coast Region Breakfast Club at Original Mikes on November 5th.
Seared
Andreas
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
New pressure plates often restore what little effort the clutch should offer. This in addition to a new slave cylinder and at least regreased needle bearings and cross shaft. A new t/o bearing should take out any pulsing one feels in the clutch pedal. Pilot bearings always seem to be in great condition, however.
I'm still incredibly curious about replacing the cross shaft with the engine in the car. I know ViperBob explained it last week and I don't think I need to pull my tranny anytime soon, since I already have a LWF/RS clutch. But I almost feel like doing it again just to say I did it. Anyone in the DC area planning on DIY'ing a LWF anytime soon? I really want to do this.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
As Bob mentioned, the most difficult part is reinstalling that shaft with needle bearings and outer races without dropping them inside the bellhousing. Then theres the little plastic plug....
Ok, maybe this has been covered here before and sorry for the hijack. But is there a cross shaft update kit with brass bushings like for the early G50 Carreras? Didn't Porsche learn their lesson with needle bearings in this area? Unfortunately, I was not allowed to DIY my LWF by the insurance co. and shop. So I didn't see whether they reinstalled the old set up or an updated kit. Wouldn't it be vastly easier with bushings?
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I typically replace these needle bearings with new needle bearings. The old, worn ones, at least the ones I have examined, seem to still have life in them.
Go for it Rick. The shear joy of knowing you did it will give you a big smile. Just take your time.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Snap-On's duck bill plier works well for things like this. Bob, that is the perfect application for such a tool
Technical Guru
Originally Posted by nile13
I wish we could get rates like that. I'm being quoted $800 for a clutch and LWF job locally.
