OMFG! Cracked Transmission Bellhousing Lobe
Technical Guru
Has anyone ever seen a cracked transmission bellhousing lobe? This is the part of the transmission that the clutch release shaft pivots in? Mine looks like it broke away in two places. I'm pulling the engine tomorrow and hopefully a local machine shop can weld it back together but if anyone has any suggestions for how-to reinforce this I'm all ears, retail $$$ for just this part of the bellhousing is $1900USD.
![](http://members.rennlist.com/jandreas/TransmissionCrackedLobe.jpg)
Perhaps www.vanzweeden.com could help you? If your shop cannot repair the component.
Weird. The area is not under much stress I would think.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Anything, including castings, is fixable. The machine op for milling that bore should be easy to get to with a mill post weld. Trouble is, one has to locate that bore unless you have access to drawings.
I have heard of these breaking when the cross shaft doesnt engage the 'blind' side bore, or 'misses' it upon assy. Doesnt appear this is the case for you, though.
Wow, this is a weird one..
Technical Guru
I pulled the engine/tranny and both ears are broken.
So I will drop the tranny off at a local machine shop later today and we'll see what happens.
Does everything else look OK? All I can think of is if somehow the pressure plate jammed, or the throwout bearing got locked onto the guide tube, then all of the force in activating the clutch would be pushed forward through the fork and into the shaft. I am reaching here, but to break both ears like that has to be caused by something.
Jason,I am sorry to hear of your problem,I have seen it before.I think it is caused by the bearings that the shaft rided in seizing up and the ears just snap off.We have fixed many and I also have a bell housing if it came to that,which would be very inusual.Let me know if i can help,good luck,Jerry
Technical Guru
Originally Posted by Rick Lee
I think this is not uncommon with the early G50 Carreras. Plenty of dicumented cases like this on Pelican and it's usually an easy repair.
