Non-airbag steering wheel swap
I am about to replace my 4-spoke airbag steering wheel with the non-airbag GT2 wheel. I have read that in order to fool the on-board electronics into believing that the airbag is still present (and thus that the passenger side airbag can still be deployed) a 2.9 Ohm 1/4W resistor should be wired in, substituting the drivers airbag. However, although this will prevent the warning light from coming on what will happen if the airbag IS to be deployed? Won't applying a firing voltage to this line burn out the resistor before the airbag goes off? Wouldn't a more hefty resistor (576W since P=V*V/R) be required to guarantee airbag deployment? Or is this line a sense circuit independent of the firing circuit? Also, just how accurate does the resistor have to be?
Any help greatly appreciated
But you're runnign it in line, so a very small voltage drop actually occurs at the resistor.
God, I used to be a geek (crossed out) an electrical engineer and though about the same thing in the same terms until the answer dawned on me
Thanks for the explanation Mike, have you done this DIY? BTW it's the P93 Cup wheel, not a GT2, as available from Gert (pic attached). Was this wheel used on the GT2's? Sorry to cruelly raise the expectations of you wheel afficianados only to dash it on the rocks - my bad
I'll tell you what I want to do. I want to get my hands on a 930S wheel from AJUSA and adapt it to fit my 993.
That has got to be, hands down, the best looking steering wheel ever made.
I wonder if you could use a MOMO hub adapter to make it fit the 993 shaft.
The resistor is placed in series to take the place of the airbag to fool the ACM into thinking that it is still there. The airbag is @ 2.9 Ohms. You cant vary it much. Maybe .1, or .2 tops. The ACM takes a voltage drop reading across the bag (resistor) to determine if anything is wrong with the system. --If it were open, it wouldnt get any voltage back, and turn on your airbag light--which is what youre trying to aviod by adding the resistor. Same thing if it were shorted together. In theory, the other airbags should still work fine if you put the resistor inline, however if your airbag light is on, they will not, hence the resistor install.
Leland:
I am doing the 930S wheel in my TT.
I got the factory 930S wheel for thr euro 964/965. The hub spline and spacing is correct for the 993. I need to make sure the turn signal cancel will work and I got the airbag shunt resistor as well. As fall sets in, this is one of my "little" projects.
Look for a post with photos when I am done.
Regards
Regards
Jim, that sounds like a great project. I am excited to see some pictures. You do bring up a good point though. I didn't think about the turn signals.
I'm interested to see how you get past this problem.
I don't like the AJUSA/RUF airbag wheel. It is about as graceful looking as a Mac Truck hauling cow poop.
