993 Forum 1995-1998
Wheels just arrived - help please
Old Oct 10, 2005 | 03:09 PM
dhicks's Avatar
dhicks
Default Wheels just arrived - help please
My new wheels have just turned up....the blurb before I ordered said 52mm offset...front and rear but the wheels have now arrived and the box says 18x8.5 + 52 offset and 18x10 + 58 offset......how much differnce does this make tom the tires I fit......was planning 265s at rear....I know VERY little about wheels n stuff so need some help here....thanks
Old Oct 10, 2005 | 03:28 PM
Flying Finn's Avatar
Flying Finn
King of Cool
It should be actually better with 58 ET than with 52 since OEM ET for those rears is 65.
Old Oct 10, 2005 | 03:31 PM
AOW162435's Avatar
AOW162435
Seared
David,
For reference, my new 18" Turbo twists are 52mm front offset (8" width), and 65mm rear offset (10" width). The new tires are 225/40 front and 265/35 rear. The car looks perfect with this setup.
I'm not sure if the offsets you received will be a problem. Others will certainly chime in with real knowledge
Andreas
Old Oct 10, 2005 | 03:52 PM
David in LA's Avatar
David in LA
What Fin said...those will fit...the ET58 only moves the wheel out 1/3" of an inch and have less potential fit issues than the ET52. You can also go w/285 if you like if you want a more meaty look.
What wheels did you get? I love wheel ****!
Old Oct 10, 2005 | 04:15 PM
dhicks's Avatar
dhicks
David - thanks, just so that I understand a little more is there somewhere I can read about offsets and wheel stuff....cant find what I want in archives....in effect where does the offset get measured from......if I were to go with 285s will they fit without problems and without rolling fenders....will they be x35 still????? people say pirellis are good but awful wear....should I consider something else....the wheels are the ones I posted last week, a little like cargraphic ones.....dont have pic available on this computer
Old Oct 10, 2005 | 04:21 PM
AOW162435's Avatar
AOW162435
Seared
David,
This might shed some light on how offset is measured:
Andreas
Old Oct 10, 2005 | 04:22 PM
TheOtherEric's Avatar
TheOtherEric
I'm not so sure they'll fit. David- is your car lowered? What neg. camber do you have in the back? If you have a lowered car with stock alignment then I think it'll be close.
p.s. if you're lowered you'll never get 285 to fit.
Old Oct 10, 2005 | 04:32 PM
InTheAir's Avatar
InTheAir
Originally Posted by AOW162435
David,
Andreas
Thanks for that, Andreas.
Old Oct 10, 2005 | 04:37 PM
dhicks's Avatar
dhicks
Thanks for all the above....is the diagram from the tirerack site...I knew there was one on there but could not find the link in...thanks...so If I am lowering next year (that is the idea) I should go with 265x35's....thanks
Old Oct 10, 2005 | 08:13 PM
RT7's Avatar
RT7
They will fit, even if your car is lowered.
Old Oct 10, 2005 | 08:14 PM
Martin S.'s Avatar
Martin S.
Talking The Other Eric and 285s?
My car is lowered with 2.5 degrees of negative camber in the rear. I have 285s on 18" wheels with the 65mm off set, they fit just fine no rubbing. Perhaps it is because of the negative camber....mine is a narrow body car.
On to another note...some folks prefer the 265/35/18 to the 285/30/18 as they feel the 35 series gives a slightly better ride....a while back, I did move down to the 265/35/18s for this reason.
I now have a set of 285/30/18 on the Mille Millia wheels. As mentioned above the fit is fine, no rubbing.
I am going to put these 18" wheels up for sale in a few days...I have had them less than a month. They were an impulse buy from a fellow Rennlister.
Old Oct 10, 2005 | 10:05 PM
David in LA
In addition to the diagram Andreas posted, you can get an idea of how much your inboard or outboard clearance will change using an offset calculator - here's one www.1010tires.com/WheelOffsetCalculator.asp. Also keep in mind that tire profiles differ among manufacturer and that difference can result in effective widths as large as 20-25cm
and if you want to roll the fenders and are gunshy about using the oldschool method, you can rent a tool....fender rolling party anyone?!? http://www.purems.com/products/descr...9&CA=408&PA=10
Old Oct 10, 2005 | 10:19 PM
Mark in Baltimore's Avatar
Mark in Baltimore
Eric,
My C2 is about as low as you can go and still be able to turn the wheels and a 285 MPSC will definitely fit. Hell, I think I can get a 295 to squeeze in back there and will give it a try next year or after the CMP or Roebling race.
David in LA,
Again, thanks for all of your help.
Old Oct 10, 2005 | 10:40 PM
George A's Avatar
George A
Originally Posted by Mark in Baltimore
Eric,
David in LA,
I'm currently running 295 MPSC's in the rear of my C2 on the stock 10 inch hollow spoke with the 65mm offset. Oh yeah, I just got a set of Hoosiers in 305/30-18's and they fit!!!!! It is on a set of 10.5 inch Forgelines with a 56mm offset.
George
Old Oct 11, 2005 | 03:38 AM
pcar964's Avatar
pcar964
I know a guy locally selling some barely used 295 Pilot PS2s, I was wondering if these would fit on my 10" rears... hmm....
