993 Forum 1995-1998
Painting Rotor Hats
Old 10-05-2005, 02:14 PM
Bruce SEA 993
Bruce SEA 993's Avatar
Location: Lat: 47 Deg 26.848N Lon: 122 Deg 21.341W Seattle
Ther was a thread here recently where a lister won a concours class with his 993. On the rotor hats he used "chrome"/aluminum paint so th eye didn't see a break from the wheel to the rotor.
I am not so sure that that paint will hold up in real world use...David asked for something long term.
I might give it a try as they will look better than they are! Sand blasting and coating sounds good but I don't have access to a blaster right now.
Cheers
Old 10-05-2005, 02:19 PM
ceboyd
ceboyd's Avatar
the 993 Eric picked up from Marina Del Ray had YELLOW painted hats (stock black 993 brakes).... not sure what type of paint used (probably the caliper paint available) cause it was strong and held up well... but got thrown away with the big red upgrade...
Old 10-05-2005, 02:37 PM
dhicks
dhicks's Avatar
Adavanced Autoparts do a caliper paint - red - blue and YELLOW.....hey Chris W. ...you out there...the yellow really is YOUR color!....Seriously....just been into AAP and they also have some engine enamel....up to 500 degrees and 1200 degrees in all sorts of different colours!!!
Old 10-05-2005, 04:59 PM
Jeff A 993
Jeff A 993's Avatar
Hi --
I went with a high-temp non-rusting type of paint, trying to match wheel color.
Cleaned rotor 'hat' and masked off caliper, covered with plastic remaining parts that I didn't want silver, and started painting. Many light coats. Still looks new after 1 year, 6k miles, untold washings (including some winter driving when roads are nice).
Good luck -- Jeff
Old 10-05-2005, 05:06 PM
Jeff A 993
Jeff A 993's Avatar
Forgot to show the post-painting pic (with some residual silver paint on the rotor).
Old 10-05-2005, 10:43 PM
Marine Blue
Marine Blue's Avatar
When I used to show my 500E I had a new set of rotors electroless nickel plated. The cost should range from $100 to $150 for a set of four. The plating obviously wore off of the braking surface but the balance remained shiny and beautiful silver. I can't vouch for the long term results but I know a few other 500E owners also gave it a try with good results throughout the life of the rotors. Might be worth investigating.
Old 10-05-2005, 10:49 PM
InTheAir
InTheAir's Avatar
Here is also a thread I saved for reference on this subject:
https://rennlist.com/forums/964-forum/156760-quick-appearance-upgrade-pt-2-a.html
Old 10-05-2005, 11:22 PM
Marine Blue
Here's a shot of the rear nickel plated rotor.
Old 10-06-2005, 08:10 AM
Marine Blue
Try again
Old 10-06-2005, 08:11 AM
dhicks
dhicks's Avatar
Wow is that cool or what !!!
Old 10-06-2005, 11:13 AM
Jeff A 993
Jeff A 993's Avatar
In the other pics of the rotor hat painting, the wheel wells and surrounding area look as bad or worse than the offensive hat! But with those cars being dark color I suppose it doesn't show up as much.
With a white car such as mine, I find that keeping the fenderwells clean really accents things like silver rotor hats, polished brake bleeders, cleaned-up dust-shields, etc.
fun fun fun...
Kind of a micro version of the slippery slope: wheel-well detaling...
Old 10-06-2005, 11:53 AM
TheOtherEric
TheOtherEric's Avatar
Ughh. I better not even comment on that nickel plated rotor. Very uhhh "concourse" if that's your thing.
Old 10-06-2005, 01:00 PM
dhicks
dhicks's Avatar
Thanks Jason....thats more or less what Jeff at Sunset says....if I paint at all it will be for cosmetic reasons
Old 10-06-2005, 01:19 PM
ceboyd
ceboyd's Avatar
I think I'd go for anodized long before I'd go for nickel plating... but that is just me I guess...
Old 10-06-2005, 01:50 PM
Marine Blue
No doubt any painting or plating is for cosmetic purposes only for the most part.
Anyways the nickel plating was recommended over anodizing by every plating company I spoke to when I was searching for an answer......just what I've come across. Powder coating would also work but again, it costs and is it really necessary.
BTW the nickel held up well even on regular canyon runs trhough Mt Palomar and Ortega Hwy for those who are familiar with SoCal. No signs of discoloration or peeling/chipping.
Quick Reply: Painting Rotor Hats
