993 Forum 1995-1998
No Warm-Up Required?? What do you think??
Old 10-02-2005, 02:49 AM
Aussie Alan 993
Aussie Alan 993's Avatar
I'm converted, I see the light and will spread the Good Word.
Thanks to all who have commented, your wisdom is en-lightening as usual.
AA993 (I have been abbreviated)
Old 10-02-2005, 07:45 AM
TB993tt
TB993tt's Avatar
I was a little confused when on reading the manual for a new Yamaha F80 4 stroke outboard motor, it stated to let the motor idle for 3 minutes before setting off. These motors have the latest computer controlled EFI. What gives here, I know its an outboard, but ........
Old 10-02-2005, 01:31 PM
deltawedge
deltawedge's Avatar
Is it a water cooled two stroke? If so, it is good advice. The two stroke combustion cycle puts more heat into the pistons because of the two power strokes per revolution and leaves less time for cooling. So in a water cooled motor during a cold start, the cylinders have much more cooling capacity that the pistons and the heavy load due to marine use can cause the pistons to heat faster than the cylinder bores. This could cause a seized piston...not good.
Quick Reply: No Warm-Up Required?? What do you think??
