993 Forum 1995-1998
Dirt cheap lifter source!!!!!
Old 09-13-2005, 04:17 AM
JasonAndreas
Technical Guru
JasonAndreas's Avatar
Originally Posted by Rick Lee
I can't imagine there are too many aftermarket manufacturers for these.
Febi Bilstein is the only aftermarket supplier I've seen, their part number is 21699.
Old 10-29-2005, 03:27 PM
cowtown
cowtown's Avatar
How did this work out for all of you who ordered? I'm lifter shopping.
Old 10-30-2005, 09:04 PM
Rick Lee
Rick Lee's Avatar
Haven't gotten mine yet, but I'm in no hurry at all, as I don't need them. I'll call to check tomorrow.
Old 12-15-2005, 04:00 AM
Mike J
Mike J's Avatar
Any updates on what happened? Did everyone get their lifters? I am only asking because I have started shopping for parts for my rebuild.
Cheers,
Mike
Old 12-15-2005, 10:04 AM
Rick Lee
Rick Lee's Avatar
I guess I'll give Jerry a call. I told him to put me last in line, since I don't need them. But now I need to order some small maint. stuff, so I'll give him a ring and report back.
Old 12-29-2005, 08:31 PM
cowtown
cowtown's Avatar
Any word on this? They're listed as "out of stock" on his site.
Old 01-30-2006, 11:56 AM
Rick Lee
Rick Lee's Avatar
Got my lifters this past Sat. in the mail. I don't even need them, just wanted the great price for someday. If there's any way to tell which size my car has without taking an old lifter out, Id like to know. If I have the wrong ones, I'll trade them to someone else who needs them and has the ones I need.
Old 01-30-2006, 12:03 PM
Mike J
Mike J's Avatar
Hi Rick,
What was the price in the end?
Cheers,
Mike
Old 01-30-2006, 12:14 PM
Rick Lee
Rick Lee's Avatar
I think $14 and change per lifter.
Old 01-30-2006, 12:24 PM
viperbob
Former Vendor
viperbob's Avatar
Rick, and Jason,
These are readily available anymore from multiple suppliers. Besides Febi. GER and LUK are just two of the ones that distribute them. They are also dirt cheap and just as good as factory. I sold my last ones for $12 each. So MUCH better than getting them from a Porsche dealer.
Old 01-30-2006, 07:15 PM
JasonAndreas
Technical Guru
As long as there hasn't been any work done on your valvetrain (guides or valves or etc. replaced) you should be fine using the standard size. Its only if you've had work done on the engine that you'll need to do the measurements and than hopefully your engine rebuilder wrote this down for you when he took the measurements.
Old 01-30-2006, 09:36 PM
Steve Weiner-Rennsport Systems
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
Jason speaks wise words,....
Whenever we do a valve job on 993 heads, the total installed height of the assembly is carefully measured and noted so the overall lengths of the valves are maintained after they have been ground.
This ensures that the original lifters can be used.
Old 01-30-2006, 10:32 PM
Rick Lee
Rick Lee's Avatar
Ok, what constitutes "standard size"? My engine has not yet been apart.
Old 01-30-2006, 11:36 PM
JasonAndreas
Technical Guru
The standard size is porsche part #993-105-141-05, the slightly (0.5mm) shorter lifter is #993-105-141-51 and the even shorter (1.0mm) lifter is #993-105-141-61. THIS thread goes into a little more detail.
Old 01-31-2006, 12:03 AM
cowtown
cowtown's Avatar
Originally Posted by viperbob
Rick, and Jason,
Any hints on where to find them?
Quick Reply: Dirt cheap lifter source!!!!!
