Possible 993 Purchase
Put another way, right now it seems prudent for me to future-budget a valve guide job to insure the root cause is fixed.
Thanks and apologies for a new thread on a well-trodden subject.
Look at it this way ... the car, if it's a nice example, will not depreciate nearly as much as most other performance cars, so the $4k more that, say, a BMW M3 might depreciate over a couple of years would pay for the valve job if it became necessary.
Vic
95 C4
Plenty of theories for the cause. Mostly relating to low speed stop and go driving and a lack of preventative maintenance. Seems like a hit-and-mis situation.
Good luck in your search. Let us know what you purchase.
_% Have had it and post on RL to help others.
_% Have had it and don't post about it.
_% Don't read RL, so you would never hear from them here, had it or not.
_% had it at <50K miles, _% at 50K-100K, _% over 100K
_% over 100K never had it (myself included)
It depends on type of driving, maintenance, engine cover on/off, concurrent with worn valve guides or not ...
The search function at the top of the page, and PPI is your friend.
c
Vic
95 C4
There are soooo many variables to take into consideration it'd be almost impossible to come up with a percentage of cars affected.
For what it's worth, I know 6 guys with 993's, not including myself, who haven't had valve guide problems. As with any automotive forum. People don't typically post threads titled "My car is perfect -Everything's OK" or "No valve guide issues here."
I subscribe to the theory that valve guide wear is linked directly to maintenance, driving style, and the environment in which the car was used. For instance, I'd be more concerned if looking at a later, hotter running 911 (3.2-3.6), with little to no maintenance documentation in some of the southwestern states. And I'd be especially concerned if that engine undertray had never been removed.
As for the CEL issue... who knows, it does seem to be a more chronic problem associated with the OBD II cars. I feel that this is just one more good reason to shop for an early '95 model.
Of course I'm biased, but everytime I read a "CEL nightmare" or an "Immobilizer malfunctioning" thread, I thank god I bought an early build '95.
OT but are there some 95s that came without the basket handle?
c
Valve guides have been spotty for years on 911s ... there are 3.2 Carreras that needed valve guides at 8k miles (Charlie Kindel's car was a notable example) and 3.2 Carreras that are well over 100k miles and have never been apart.
Replacing the factory guides with harder ones will cure the guide problem once and for all, but it won't guarantee that the SAI passages won't get clogged again and require attention.
Vic
95 C4
Vic
95 C4
I bet mine are clogged up, but I'll never know (unless I tear the cam towers off) because the OBD I doesn't care.
i did not have excessive oil consumption, but i did have plugged SAI/CEL problems.
As for preventative measures related to SAI issues, I know several reputable shops believe strongly that the main culprit is the SAI check valve. As has been posted on this forum numerous times, when the check valve gets crudded up and stops functioning properly hot exhaust gasses are allowed to flow backward into the ports and cause excessive carbon build-up. I know Hergies recommends changing the valve every 15k miles or so.
As for guides, my car grew up in the upper mid-west and appears to have began having clogged SAI ports as early as 25k miles (based on very detailed and complete maintenance records). I didn't have any records of oil consumption but realized quickly after I purchased the car (at 39k) that I was burning way too much oil (a quart in the first 500 miles).
My guides were shot and my ports were plugged, so a new top end was my only real option. I don't know the driving habits of the PO, but I do know from the records that the car was well cared for and had oil changes frequently.
I believe my car is in the minority as far as these issues go, and that more than anything else I was just unlucky. However, I'm not certain that reliance on good records, strong PPI results from a reputable shop, and otherwise proper due diligence will necessarily keep you trouble-free... ask me how I know.
