993 Forum 1995-1998
Immobiliser.
Old Aug 28, 2005 | 01:02 PM
RustyRotors's Avatar
RustyRotors
Default Immobiliser.
I am not liking the procedure I have to go through to start the car. Especially the wife. She is paranoid about stalling at a traffic light and having to relock and then unlock the car then wait for the light in the dash to go out and then push the button and then turn the key and hopefully it cranks. Can this immobiliser be turned off without disabling or affecting the functionality of the central locking / unlocking of the doors or the alarm?
Ron
Old Aug 28, 2005 | 01:14 PM
ceboyd's Avatar
ceboyd
nope.. do a search.. this has been discussed at length.. believe me, I'd love to disable the damn thing!
Old Aug 28, 2005 | 01:25 PM
Howdy993's Avatar
Howdy993
Hmmm
Yet another good reason to own a Tiptronic
Best wishes
Old Aug 28, 2005 | 01:33 PM
Terry Adams's Avatar
Terry Adams
Veteran: Army
If you stall at a light you have I believe about 90 seconds before you need to do the lock/unlock thing. By then the light has turned red and you have even more time.
Old Aug 28, 2005 | 01:38 PM
BIG-BRO's Avatar
BIG-BRO
In the event of a stall, you don't need to go through that procedure at all........ just turn the key back to vertical and restart - no push of the button, no waiting.....
Old Aug 28, 2005 | 02:33 PM
ceboyd's Avatar
ceboyd
that is true.. as long as the key is still in the ignition, you just need to restart without removing the key...
Old Aug 28, 2005 | 02:36 PM
Phil's Avatar
Phil
Phlat Black Guru
Lifetime Member
- Times 2
correct...
Old Aug 28, 2005 | 02:43 PM
RustyRotors
Default I'll give it a try.
Originally Posted by Fill
correct...
I will stall it in the driveway and see if I can just restart it without the long procedure.
Thanks all.
- Ron
Old Aug 28, 2005 | 03:29 PM
STLPCA's Avatar
STLPCA
Addict & Guru
Once the car has been started, the arming sequence will not begin until after the key has been removed from the ignition - regardless of time. A restart after a stall is no different than in any other car.
Old Aug 28, 2005 | 03:39 PM
Crimson Nape Racing's Avatar
Crimson Nape Racing
When at a DE, I leave the key in the ignition all day and never have to go through the lock/unlock stuff. Any other time, I just the lock the car when I get out (even in the garage), so it is really no big deal once in the habit.
Old Aug 28, 2005 | 03:47 PM
ceboyd's Avatar
ceboyd
same here.. I just leave the key in all day long.. to much a PITA to go through all that crap.. besides, I've never seen anyone trying to jump in my car and drive away at a DE anyway... (first they'd have to fit in my race seat.. LOL)
Old Aug 28, 2005 | 04:06 PM
ca993twin's Avatar
ca993twin
You folks keep mentioning "lock/unlock"... you don't need to do that anyway... just turn the ignition on, press the immobilizer button, watch the immobilizer warning light go off, and start the car.
Old Aug 28, 2005 | 11:49 PM
David in LA's Avatar
David in LA
Originally Posted by RustyRotors
...Can this immobiliser be turned off without disabling or affecting the functionality of the central locking / unlocking of the doors or the alarm?...
if you have a 97-98 then you can reflash the ECU
Old Aug 29, 2005 | 12:08 AM
ceboyd's Avatar
ceboyd
...true BUT it doesn't always eliminate the alarm immobile thingy permantly...
My 97 ECU was redone and I wanted it eliminated.. but Steve told me it might or might not work.. In my case, It was eliminated for about 3 trys and then came back ..so I'm stuck with it....
Old Aug 29, 2005 | 01:03 AM
Rick Sylvestri's Avatar
Rick Sylvestri
I'm all new to this and should receive my car from Intercity lines Monday or Tuesday, I've done some searching and sounds like "leave the key in, when it's safe at home, Ax/DE ect....OR put the key in the ignition, turn until the dash lights up (on position), hit the immobiliser button & start the car. If you stall the car treat is as a normal car, turn ignition off and re-start the car.
If this is not the procedure... please let me know
Thanks, Rick
