Oil Guage Stuck
The Oil Level guage on the left side of the speedo is stuck at bottom. A few questions:
1. Where is the sender located?
2. Is there a method for testing the guage and the sender?
Thanks,
Joe
Thanks,
Joe
Phlat Black Guru
Lifetime Member
- Times 2
Lifetime Member
- Times 2
1 Post
Joe,
its pretty much agreed that the most accurate way to check the oil level is via the dipstick.
You might try tapping the gauge, and see if you can get it too move a bit.
Phil,
Thanks for the reply. I agree on the dipstick as it's the most accurate guage but I'd like to keep all the parts of the car in working condition. I'll try giving it a tap and cleaning the contacts as suggested in another thread, but if that isn't successful something more in-depth may be called for.
Joe
Joe
Are you sure its stuck? how do you know its not low on oil? The sender by the way is in the oil tank (pass side rear fender under fender liner) and runs around $85 to replace, so make sure its "stuck" before you change it.
Okaaayy...I re-checked the dip stick and maybe it was a bit low....well, maybe more than a bit as I added a quart of oil and after driving the guage responded. I think the simplest answer is appropriate here...low on oil. I've been a Porsche owner for 25 years and there's always something else to learn. Thanks Chris and Phil for the responses.
How long after your drive did it take the gauge to respond? My gauge permanently sits in the red like your's did and still does after adding a quart and a 20 mile drive.
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
almost immediately...I actually added more than a quart. Maybe you are still low?
The most important thing here is to try to measure at a consistent engine temp. The oil level changes quite a bit with heat. I try to measure the oil at around 9 oclock. Also need to measure on a level surface, preferably the same place all the time, like your garage. Don't feel bad about checking the stick mutliple times. I bet there aren't many of us who don't do that.
Originally Posted by Arrwin
That is possible, but I just don't want to overfill. I'm having a hard time deciphering smudges to actual readings with the dipstick. I'm not confident that it is low and/or my gauge sender is not working.
Reading the dipstick is a bit of an art.
Wipe the dipstick until it is completely dry, insert it all the way to the seat and then withdraw, look at it wuith the light at a glancing angle and itr is pretty apparent where the oil level is indicated. Also, why not enlist the aid of a Renn list member near you to show you how to properly read the dipstick?
Thanks guys. Took the car out to lunch and it appears that the gauge is indeed functional as I saw some movement at ideal hovering right about the 'red' range. So....looks like my oil was/is indeed low. I will probably add a 1/2 a quart more, which should be suffice to put it back "in range".
Didn't mean to beat the topic to death, not like it already hasn't, but I guess it takes (me at least) a false alarm like this to really learn this whole aircooled thang.
Didn't mean to beat the topic to death, not like it already hasn't, but I guess it takes (me at least) a false alarm like this to really learn this whole aircooled thang.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Originally Posted by 993inNC
Thats how you learn, don't sweat it. But a half quart wont do much, it will probably cause the gauge to read at about the 4 o'clock position or less when warm. One quart should bring you to half gauge and 2 will bring you full. Oil expands (and foams) when hot, but also tends to loose viscocity as well so why run low? Fill it up, you wont hurt it. That last quart or two will go in slow, so watch out, don't rush. And you don't need it warm to fill it, start the motor to get the oil moving out of the tank and through the system, then shut 'er down and fill before it gets to hot to be in the engine compartment.
Thanks.
Arrwin,
My oil gauge only seems to work when I change the oil, after about a week, it completely drops to empty. I may have a problem with my sender, but I've just relied on the dipstick.
-nelson
-nelson
