993 Forum 1995-1998
Engine ka-boom follow-up
Old 08-11-2005, 11:31 PM
  #31
the_buch
the_buch's Avatar
So .... if I happen to be skilled at double-clutching and heel-and-toe rev-matching, then it does not put too much strain on the engine to use it as a brake by getting off the gas in anticipation as traffic situations change around me??? .... otherwise, I would have to stay on the gas until I immediately transition to the brake which does not make sense to me???
Thanks,
Old 08-12-2005, 01:58 AM
  #32
Steve Weiner-Rennsport Systems
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
Hi Doug:
The key thing is NOT to back off the throttle from high revs in the lower gears as thats what really stretches the rod bolts and initiates the process. Such activities have cumulative effects.
Rev-matching, upshifting as necessary, and using the braking system to slow the car to the appropriate speed for the gear you are using, are the main things to remember.
Old 08-12-2005, 02:43 AM
  #33
ceboyd
ceboyd's Avatar
Originally Posted by Steve Weiner-Rennsport Systems
LOL,..I recommend using the engine to accelerate the car out of a corner and beyond. I think one uses the brakes to slow the car to the corner entry speeds that you are comfortable with.
Brake pads/rotors, etc are really far cheaper than engine parts,....
yeah.... I go through rotors and pads quicker than my 6-speed counterpart with my Tip.. who new my Tip could be beneficial in the fact that I don't 'engine brake' and can't overrev.....
Old 08-12-2005, 04:38 AM
  #34
Originally Posted by ceboyd
who knew my Tip could be beneficial in the fact that I don't 'engine brake' and can't overrev.....
LOL,...You are wiser than your years, Ms. Boyd,....
Old 08-12-2005, 11:26 AM
  #35
infinii
infinii's Avatar
Thanks for the replys. Sorry for going a bit off topic there Tom, that wasn't the intent.
I hope your car has a speedy recovery. If the $$ is there consider 3.8, it's probably the biggest power gain available for your car and now you have an excuse.
Old 08-12-2005, 12:41 PM
  #36
Tom W
Tom W's Avatar
I considered the 3.8 (and many other performance options) for about a millisecond. It costs way to much and does not provide that much power. Not to mention that it puts me into a totally different race class where I don't want to be.
It will likely cost me $10k (plus or minus a couple k) to replace the engine and get a new one in with Carrillo rods and stronger valve springs. Throwing another $20k at it to go to a 3.8 is not what I want to do. I want a stock/prepared class engine that will last a few hundred hours before I have to do anything more to it (other than routine maintenance).
Old 08-14-2005, 05:54 AM
  #37
sharkster
sharkster's Avatar
man and i thought bending my rods was bad Sorry to see that...
Quick Reply: Engine ka-boom follow-up
