993 Forum 1995-1998
car jacking plates???
Old Jul 30, 2005 | 06:33 PM
ca993twin's Avatar
ca993twin
Question car jacking plates???
I recently saw on the rear of someone's 993 (I can't remember who... old age), a nifty aluminum plate that bolts to a mount at the rear of the engine, and can be used to jack up the rear of the car. I'd really like to get one of those. Who sells them?
Performance Products sells a "jacking puck" which can be used at each jack point to raise an individual wheel ($29.95). That seems like a good way to do the front.
Old Jul 30, 2005 | 06:39 PM
kkim's Avatar
kkim
Steve,
Are you referring to this?
http://p-car.com/diy/jacktowpoint/
edit-
to further finish on the lifting theme... I use one of these plates when jacking from the rear lift point to get the front up in the air...
I then set the car down on jackstands made by ac products...
And as BobbyT said, I lift the rear of the car using a low profile jack w/ a hocky puck between jack cup and engine case and set it down on 2 more ac jackstands at the rear jacking points.
Makes for a safe, solid method to raise the car and put it up on jackstands so I can feel confident to crawl under that pig to do the work.
Old Jul 30, 2005 | 06:44 PM
ca993twin's Avatar
ca993twin
Kelly,
Yes, <gulp> that's the one. But $265? Yipe-o-rama. Are there any other alternatives? Anybody?
Old Jul 30, 2005 | 06:49 PM
David in LA's Avatar
David in LA
Originally Posted by ca993twin
Kelly,
I got mine when Ron put together a group buy some time ago. I didn't get the tow hook part (since I don't track this car yet) so it was a bit cheaper. Only takes a few minutes to install and makes lifting the rear end much easier.
Old Jul 30, 2005 | 06:50 PM
BobbyT's Avatar
BobbyT
A hockey puck in the jack cup, or between the jack stands and the jack points on the car, works well for me.
Old Jul 30, 2005 | 07:16 PM
ca993twin's Avatar
ca993twin
Can I use the hockey puck and jack under the engine?
Old Jul 30, 2005 | 07:17 PM
TrackJunke's Avatar
TrackJunke
I believe autometrics sells one.
Old Jul 30, 2005 | 07:26 PM
ca993twin's Avatar
ca993twin
TrackJunke,
Thanks... good resource, but its the same part... for the same $265. I'd like to have the plate, but that's about 2x what I'm willing to pay.
Old Jul 30, 2005 | 07:27 PM
kkim's Avatar
kkim
yes, if you are careful where you position the lift point.
check out the DIY on Robin's site...
http://p-car.com/diy/jack/
Old Jul 30, 2005 | 10:08 PM
ca993twin's Avatar
ca993twin
I still like to have that plate... anybody want to sell a used one?
