How much Ice Wax?
I have used almost a whole bottle of liquid Ice Wax to try to stop noises from top of Windshield. It has had no effect.
To verify: I am lifting the trip piece with a plastic spatula, and dribbleing the Ice Wax into the deep groove that is closest to the body. Am I doing it right? On the pics that are posted here are tough to see exactly where the stuff needs to go.
Do I need to wait a few days for it to work in? Or does it take more Ice Wax?
Are you using the aerosol can? If not, it would be much easier to apply. Also, are you going around the entire windshield, top and bottom?
Yes, you are correct... apply to the rubber gasket side nearest the body.
edit-results should be immediate.
Still plays with cars.
Note - any good chain lube will work as long as it is the type which goes on wet and dries to a waxy substance. I used Maxima Chain Wax with success. You need to do the entire seal, top bottom and sides. Using the spray nozzle makes it simple. You can also apply silicone grease instead although it is not as convenient to apply as the chain wax.
Troy
I agree that silicone lube works but the chain wax lasts much longer and also comes with a small tube like WD-40 so that's why it is preferred. Chaini lube goes from a liquid which penetrates well (think about the clearances in a motorcycle chain) to a waxy substance which does not collect dirt like a grease would. Silicone lube washes away to easily based on my experiences. One I discovered chaiin wax I'd respray the seal every 3 months or so. Took all of five minutes using a plastic paint scraper and my Maxima Chain lube.
I did one good once around. Not only did the noise disappear, but ever hard turns yielded a major splatter of ice wax all over the side of the car.... this nice side affect lasted for over two months. But the squeak disappeared.
Pegasis - you've now defined how much is too much
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
I get a bottle of White Lightening bicycle chain lube, a 5cc syringe and tubing to fit the end of the syringe...I attach the tubing, and place the tubing into the plastic White Lightening bottle. Pull back the syringe handle and suck up the fluid...next, just go all around the windshields and inject the White Lightening…as Troy says, the results are nearly instantaneous. The tubing eliminates the need for a spatula.
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
