H&R Sport Spring #29953 - Spring Rates??
Hi Guys;
By any chance does someone know the spring rates for the H&R 993 Sport Spring kit (Part number 29953-1)
Would these likely match up suitably with a set of Bilstein HD shocks or would they be better suited for the stock shock setup on the 993?
Cheers;
Eric
Cheers;
Eric
Pretty much nothing is good with the stock shock setup.
You definitely want to go with the HD's with the H&R's. Though it does not show spring rates, you should check out Robin's site's "993 Suspension FAQ": http://p-car.com/susfaq.html.
PS. do a search on spring rate, there's lots of discussions in the archives. Good luck!
