New front track tires only?
I always wear my front track tires faster than the rears. I have always replaced all four tires when the fronts are worn. Has anyone replaced front track tires and continued with half used rears?
Thanks.
SF
Thanks.
SF
Need more info, what kind of tires are you using? I have used new Hoosier on one end (front) with a pair of 5 heat cycled Hoosiers on the rear (944 S2 race car). I takes a little finess until you get used to it. MPSC might be a little more forgiving as the stick is not as great. Depending on your level of skill and the type of tire it certainly can be done but I would be careful because it will feel different for a few sessions.
you and I need to get together. I always wear out the rears and the fronts still look great. To answer your question, I think as long as you stay with the same tire you should be ok. I buy new rears twice as often as fronts, and have not had any problems, except once when I mixed types.
Track naive question... is it typical for the fronts to wear out before the rears? If so, why???
Could it be the fronts are wearing out due to understeer or is it because the fronts are actually doing some work when the car is pushed on the track?
On the street, I go through sets of rear tires before the fronts wear out.
Any of you track junkies care to explain?
WRT to the street, the rears will usually burn out long before the fronts.
On the track, assuming the alignment is correct, wear differences between fronts and rears could be the result of under or overinflated tires, track surface, driving style or sway bar/shock set up. I tried playing around with a very "tight" set up where there was a decent amount of understeer and found that I wore my fronts much more quickly than the rears. When I made the handling more neutral, at least with my MPSC's, my wear is incredibly even from front to back as long as I swap tires left to right. I'll run out of heat cycles at about the same time that I cord the tires.
Originally Posted by kkim
Thanks, Mark.... appreciate the info.
Sounds like you have your car well sorted.
I'm chasing an oversteer issue with the car right now, and, with the Motons, I have a feeling it may be a bit before it's fully sorted.
Happy to help.
Originally Posted by Alon
Hey Mark, I'll trade you my understeer for your oversteer
I'm waiting for my H&R adjustable sway bars to arrive. They should be exact replicas of the RS bars. SO there's no adjustment left in your bar to soften it a bit? Stiffen the front up a bit then.
I doubt it can be easily modified, Alon. The bar either needs to be smaller in diameter or the connection point on the bar needs to be lengthened so that there is more "give" on the bar and less stiffness. I guess this means machining down the bar or welding length to the bar (very bad idea). Probably easier for me to simply find the right sway bar size rather than re-invent the wheel/bar.
Yes, finding a deal on an RS bar is probably the easiest route although you may want to consider the H&R version (it is adjustable). Check out www.hrsprings.com
