993 Forum 1995-1998
Gear Oil change time
Old 07-06-2005, 02:11 AM
kkim
kkim's Avatar
I try to do mine on a yearly basis. I drive about 15k miles/year.
I'm sure others will have differing opinions, though.
Old 07-06-2005, 05:16 AM
Edward
Addicted Specialist
Edward's Avatar
Originally Posted by Rob 97 993c2
how often do u have to replace the transmission oil? when do u know that it is bad?
Hi Rob,
I tracked my car about 5-7 weekends/year on my daily driven 993 with annual miles of about 12K, and so I figured under such duress I'd change the tranny oil (Mobil1 75w/90) every year. Everytime I drained it, it was still kinda dark honey colored, at least some indication that it ain't "grimed up." Now that I've retired my 993 to pure commuter duty, I think I'll go every other year (prob about 20K miles total for that 2 years) before I replace the oil. I think that is prudent given it's use. That is still *much* more frequent than the factory recommends, but perhaps an expert will chime in.
Edward
Old 07-06-2005, 08:39 AM
amfp
amfp's Avatar
I change my tranny oil with Mobil 1 75/90w every two years even with low miles. I just think is good and cheap preventative maintenance.
Old 07-05-2009, 06:47 PM
DesertBighorn
DesertBighorn's Avatar
Originally Posted by pjconner
Mobil One did not help my slight grind into second gear (probably a syncro). I had Redline Shockproof put in and it is like a new transmission. It is too heavy for your climate, but they make a lighter version.
Patrick, just found your post, do you remember which version of Shockproof you used? Sent you a PM also.
Thanks,
Doug
Old 07-05-2009, 07:31 PM
trophy
trophy's Avatar
Originally Posted by Alon
Thanks guys. I have read the p-car.com DIY for this and the author stated that he was not entirely happy with the Mobil One. As much as I wan to support my Motul friend, I would like to hear from anyone who has used it. WOrst case scenario, I'll pick up some Mobile One.
What about the Redline or Amsoil? Any thoughts?
I have been running Motul in my car for the past 5 or so years, it has been awesome for me. The car really is only a track car with approx 25-30 track days a year (so it is worked hard).....Very Happy...
Old 10-19-2009, 01:16 AM
Rick Lee
Rick Lee's Avatar
What kind of Redline is good for the Arizona climate?
Old 10-19-2009, 11:49 AM
matt777
matt777's Avatar
When you guys say Mobil 1 are you talking Delvac?
I ran Amsoil 75W90 for a year and then the Redline. I can't say there was a noticeable performance difference. I think 2nd was a little notchier when cold with the Redline but that is about it.
Old 10-19-2009, 02:18 PM
Edward
Addicted Specialist
Edward's Avatar
Hmmm, talk about an old thread!
I just recently went to Redline. Not intentional, really. I have always used M1 since it's easy to get and cheap. But since my car was at my buddy's shop a short while ago, and I was due for a change, I figured why not as it was already on his lift ...and what he uses is Redline. I felt no difference whatsoever, FWIW.
Edward
Old 10-19-2009, 03:08 PM
Texas993
Texas993's Avatar
Mobil 1 Delvac is what is recommended by transmission guru Brian Copans and my shop, RUF Dallas. That is what I use on my recently upgraded/repaired transmission. Works well.
Old 10-22-2009, 05:28 PM
Pete Lech
Lifetime Member
Pete Lech's Avatar
Default Help the Second Gear grinding when cold
I put in both Mobil One (not Delvac) and Motul around 30K miles and did not see any significant difference. Both were not quite as good as the Delvac factory fill, which we didn't know about then. I plan on trying the Delvac version again soon as I am approaching 60K miles.
One trick to reduce the second gear grinding when the car is first run: leave it in second gear when parked. You still have to shift a bit slowly at first, but it really does make a difference.
Old 10-22-2009, 05:39 PM
CaptainGSR
CaptainGSR's Avatar
Newbie question: Is that Mobil 1 75w90 the silver bottle you can find anywhere (including pep boys and walmart)? Or are there different types?
Old 10-22-2009, 06:30 PM
Pete Lech
Lifetime Member
Pete Lech's Avatar
Found some interesting items on the Mobil One Site:
https://www.mobiloil.com/USA-English...ollection.aspx
Old 10-22-2009, 06:36 PM
mongrelcat
mongrelcat's Avatar
How/why does this work?
Interesting, so Delvac is not recommended for LSDs. I noticed something similar on the Motul site, they do not have a 75w90 gear oil for use with LSDs. Royal Purple makes no distinction. Not sure about Redline.
Texas993
Texas993's Avatar
Delvac is different. For most of us, it has to be ordered. Or some pcar dealers stock it as it is factory fill for the GT3.
Try to google it for a seller.
Old 10-22-2009, 06:42 PM
NC TRACKRAT
NC TRACKRAT's Avatar
Mobil DELVAC 75W90...replaced SHC690...Available in 1 gal. tubs from Grainger Supply and www.Lufteknic.com. How often??? Different folks will give different answers. Time/mileage dependent.
Quick Reply: Gear Oil change time
