993 Forum 1995-1998
SAI Flush Update - 24K miles later
Old 11-22-2009 | 05:50 PM
  #31
PNogC2S's Avatar
PNogC2S
Originally Posted by mgventura
Wow! I like your approach, PNog. Probably faster and more effective than anything else. I guess you still would want to blow it all out with compressed air form the top after you have run the cable from below to clear out the passages and then replace the check valve.
I'm not convinced that doing a valve job to "cure" the problem is necessary or effective (unless you have a bad oil consumption problem). It'd be interesting to know how many of those cars that have had their valve guides replaced have seen the CEL light return due to the SAI issue.
Yep, you definitely will want to blow compressed air through when you finish - carbon dust will fly out and you'll see how much more air-flow you have through those things. Then don't forget to clear the SAI fault codes after you've put the whole thing back together too.
