Pre-tension on strut bar ...
Any thoughts on whether or not I should have some inward or outward tension on an adjustable strut tower bar when the car is just sitting on level ground ... also, I thought I should disconnect the bar for a ride-height adjustment and alignment, and then re-install and pre-tension if appropriate ...
thanks,
thanks,
There should be outward tension, though only 1/4 turn on my (AJ USA) bar, not sure how standard that is. I would think you would want to tension the bar, then do your balance and align, otherwise your settings can change if you tension afterwards.
What Troy means by "outward tension" is that the strut brace should be in compression, i.e. pushing slightly on the struts, which you do by installing the bar then screwing the ends so as to increase the length of the bar. Only slight compression, however.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Absolutely, in compression as already stated. Not too much as you dont want to make a widebody out of it
Oh wait a minute, I just noticed you already have one..
As I understand it, with any suspension alignment changes, you should disconnect the bar. Then set everything up and then reconnect it with only a slight outward tension.
Rumor has it that you can actually move the strut mountings inwards or outwards with not too much wrenching on a bar. So I guess less is more. In theory, if you really muscled it, you could change the camber! LOL
I also took the advice from the forum and gave it the "outward tension" to the towers. However, according to the Performance Products, it says "During hard cornering, the stock front shock towers spread apart..." - now I'm confused. By applying the ourward tension, am I not adding more pressure in the wrong direction? Shouldn't it be mounted with the "inward tension" to hold the towers from spreading apart? Perhaps I'm not interpretating it correctly, and I ask for your explanations please. Thank you.
http://www.automotion.com/ProductPag...eister&type=20
when you put outward tension like the picture below
. . . . . . . . _____________
. . . . . ___/. . . . . . . . . . .. \____
you are putting pressure/force on the towers to keep them from flexing, because when you corner, the chasis will want to flex to accomodate the extra force caused by the turn.
The manufacturer of my bar (Cup-Sport) also say to tense 'outwards' (i.e., the bar slightly longer than slack) ... as suggested above, I believe the bar should be removed for alignment and then re-installed afterwards so as to allow the spec tensioning without influencing alignment settings (albeit very slightly) ... thanks for the input so far ...
