USA & RoW Variations.
I think most ROW cars also have a 3 position headlamp adjust swich on the dashboard ( with a little servo motor inside the headlamps to adjust low beams) .
Cheers Lyndon
Cheers Lyndon
Originally Posted by Rassel
Seems more like the HP-difference you mentioned is between normal and VarioRam equiped cars. However there is a difference in HP-output between ROW and U.S versions.
I also believe the ROW cars have turn signals on the sides, just in front of the doors.
Phone console is also different.
Originally Posted by GrantG
You're correct about the hp difference being between the non-varioram (95 in US) and varioram (96-98). There is no power difference between US and ROW - just the power rating systems produce slightly different numbers (SAE vs. DIN).
Turbo S - RoW Version 443 hp (450hp DIN)
For those that didn't know:
1 hp SAE ≅ 0.745 699 9 kW
1 PS (hp DIN) ≅ 0.735 498 8 kW
PS stands for Pferdestarke, which means Horse Strength
