Fan bearing and RS pulley
Originally I was going to do the same, install RS Pulley and sell the 12 pt part, but changed my mind. If you ever need to do an alternator change, you still need the tool to hold the alternator shaft in order to remove the 24mm nut.
For this reason I thought the 12 pt tool was worth hanging on to. Stores nicely in the OEM toolkit as well.
Jeff N
Jeff N
Technical Guru
Originally Posted by Jeff96-993
what did you do with the twelve point tool after you were finished?
Originally Posted by ppressle
Hi Jeff,
I believe the 12 point fits into the alternator shaft, which will still be there after the pulley update.
I found my 10mm triple square tool on the web somewhere for about $5+shipping. I did need to cut it down to fit. kd 2305 (No affiliation)
Thanks,
Pete
Thanks,
Pete
Thanks for the link... I just ordered mine, $12 w/shipping. If anyone ever needs to borrow one just send me a note, I'm more than willing to loan it out.
Ordered the part online for the price posted above. Should be here in about a week.
I was in Autozone a few hours later and happened to see the exact same tool contained in a set with 3 other wrenches. Cost... $12. So I bought it.
I'm now 3/4 of the way through the RS pulley replacement. I'd be all the way done but the new fan belt I thought I had was really an alternator belt... I'll pick up the right one tomorrow.
Guys, the RS pulley does not allow the car to run correctly at idle. The alternator is not spinning fast enough and causes the car to run below 12 volts not charging the battery. I hate this about the pulley setup.
