Installed a steering brace on an early '95 993
For those of you wondering if the steering rack brace required to run 18” wheels on ’95 993’s will fit the early ’95 cars, I can now put that to rest. Last night I installed the new brace from Gert and it went on without a hitch. Porsche evidently put out a TSB saying early ’95 993s (between a certain VIN range) could not be retrofitted. I checked my VIN against the serial numbers found in the archives and my car fell into the “too early to install the brace” category. But, I had already ordered it and figured I’d try it and see why it couldn’t be done. My best guess is Porsche used two different brake boosters and the early ones are slightly larger in diameter. The brace comes within about 1mm of the booster, but it is not touching. I used a feeler gauge to make sure. I laid there thinking about it for a while to make sure I was missing something and came up empty. I don’t see how the brace can harm the booster. So, as far as I know the brace will fit early 993’s and I have no idea why Porsche said not to install the brace on early 993’s.
Cheers,
Cheers,
Addicted Specialist
Hmmm, I've heard of the TSB about "adding" the brace to the 95s, but never heard about them "not fitting." I've got an early-ish '95 with the brace...no problemo.
Edward
Edward
I too fitted the steering rack brace to my ´94 993 C2 (European model) last night.
Mine too was ordered from Gert and it fitted perfectly.
Didn´t really notice any difference when driving though. Are you supposed to ?
Funny to find out that roughly at same time there´s somebody else doing the same mod to 993 in the other side of the Globe!
Mika
Mika
Originally Posted by Leland Pate
Yup, the kit came with new bolts with loctite on the threads. Mika, how close did the brace come to your booster?
Now you´ve mentioned the thing I´ll have to look closer next time I´m down there.
Mika
i have a 95 993 and have installed 19" SSR GT3's why do you need a brace
for 18" + wheels?
Do i need it and what are the benefits?
I had 18" SSR GT3's until this spring and had no problems with steering
and just upgraded to 19's
for 18" + wheels?
Do a search on "steering brace" and you'll get loads of info. Essentially the brace offers more support to the steering rack. With 18"+ tires the increased lateral loads on the rack can cause premature failure of the rack assembly.
RL Technical Advisor
Originally Posted by Tom Pepper
I thought all 993's experienced premature steering rack failure. I guess you mean premature premature failure.
I think he was referring to early, premature failures.
