H&R Adj. Rear Sway Bar 24mm, H&R Adj. Front Sway Bar 26mm
Car on rails....
I have had a few Rennlisters in my car at the track Greg., including Viper Bob, the rails do get a little squirrelly now and then. I do push the car pretty hard within the limits of my meager talents.
Originally Posted by Greg Fishman
Danny,
Go to the Hoosier tires and that understeer will be gone. I had the same kind of problems with the Michelin's. At Putnam I dropped over 2 seconds on my lap time when I switched back to the Hoosiers.
would have should have...Oh well! I know I should listen to you guys
Originally Posted by akolodesh
Hi Danny,
have tried 245's up front to help combat the understeer?
Danny,
Michelin has 235's in the MPSCs same size as the GT3 uses. If/when you change to the Hoosier you may want to go with the 275 rear tire vs the 285. They only tire I have had (Hoosier) that has not done well for me was the 285.
I have the TRG bars with the Moton Club Sport suspension and have not had any understeer issues nor have I run out of adjustment on the front bar. I do like to have the car set up with a bit of understeer.
Originally Posted by DJF1
No Alex, I have been running MPSC's for the past 3 years and the max front I have had on was 225's. I'm sure with the 245 front 285 rear my car will handle much better at turn in. Unfortunately last year the S04's had so many problems with the rears so I stayed away from them. Otherwise I would have been running on these sizes Hoosiers since last year.
I think Greg has it - a 235/275 combo should work just as well.
