Rear Seat Delete Option
Technical Guru
The part number will depend on the interior material and color. For the RS/coupe the first part of the number is 993-555-123-00- (leatherette) and 993-555-123-01- (leather). For the cab it is 993-555-123-02- (leatherette) and 993-555-123-03- (leather).
Originally Posted by JasonAndreas
.......won't have a lock or alarm hookup on the two doors although it is real simple to add them.
Technical Guru
Originally Posted by David in LA
You wouldn't by chance have the part numbers for the lock/alarm wiring and solenoid would you? Mine did not come with the harness
999-919-108-02 (2) bolt hex-head 5.0 x 35
964-613-602-00 (2) contact switch
928-624-211-00 (1) element
999-591-946-02 (1) clamp 5,0
964-555-661-00 (2) end plate
N -012-435-4 (1) lock washer
900-031-001-02 (2) washer 8,4
964-555-659-00 (1) segment
964-555-657-00 (1) reverse lever
and the regular glove compartment locks, there are a bunch of different one's so you'll need to match what's already in your car.
There is no separate wiring harness (that I could find) for the cabriolets that were delivered with an alarmed rear luggage dump, the switches are connected to Auxillary Input 1 on the alarm control box. The part numbers you'll need are:
