Help Diagnose Sunroof Problem
I'm having some sunroof problems and need your help...Did a search and could not find anything similar to my problem....Here's the problem(s):
1) With roof in closed position, roof will not open but can hear the motor running
2) With roof in Open position, roof would not close and cannot hear the motor running
3) Can Manually open and close roof
Any ideas would be appreciated....
Sounds like either both your cables are broken or the gearbox is stripped. Does the motor ever stop? If it does, then the cables may still be operating and the gearbox is fine. The mechanism hasn't changed in years, it was the same on the earlier cars. Look on the Pelican Parts technical articles and you'll find steps to take it all apart then you can see what's broken. Andy's on the right track.
Chris.
Chris.
You should be able to find threads on this topic in the archives. I have written detailed instructions on how to unzip the roof lining, remove a few pieces then inspect the motor, gearbox and cables which will make diagnosis a lot easier.
Let me know if you can't find the archives.
I am able to open and close the roof manually so that's telling me the cables are fine or is that not a safe assumption
Never thought about the gearbox....
Thanks for the suggestions...I'll have to take it apart when I can find some time...
Graham, i did read your post and will use as a reference since this DIY stuff is new to me....
Just an update: The problem was 2 part:
Since I was able to open and close the roof manually, that told me the cables were fine....Pulled the drive gear and cleaned out all the gupe in between the teeth and reinstalled...
Next I Pulled the switch and the connection was loose at the back. Fixed that and voila, the roof is back in operation...
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
