Help!! Changing Spark Plugs... Dropped plug... How to Remove?
Dave,
Good advice on the spark plug socket. I wedged some small wooden dowels between the rubber insert and the socket wall so it would grab the plug better. I think I'll take mine back to Sears and ask for a new one as it's a Craftsman socket and has lost it's grip.![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Just got done w/ the fuel filter and it was a lot easier than expected. No need to remove the airbox body as suggested in the DIY on Pcar. It's a tight fit getting in there, but very doable with the airbox body still in there. I did have a short 19mm wrench from an old dirt bike tool kit that helped and I used a proper set of flare wrenches on the fuel fittings. If you want some other tips, PM me and I'd be happy to share.
Location: Lat: 47 Deg 26.848N Lon: 122 Deg 21.341W Seattle
Troy,
I learned a little trick for removing the distributor caps as the screws are usually stuck and the screwdriver strips out the top of the screw.
1. Tap on the screwdriver with a hammer (lighty) while turning in the direction to tighten the screws. This is so if the screw strips a little it is in the wrong direction. The hammer acts like an impact wrench to loosen the screws.
2. After you break the frozen screw loose in the tight direction, you can then unscrew it as normal.
If you try to break them loose in the direction you are going to remove them, the top of the screw gets stripped.
This is harder to describe than it is but it works. It beats having to drill the screw heads off. Ask me about that one!
Cheers
Cheers
Technical Guru
During one of my spark plug nightmares I reverse wrapped some duct tape around a screwdriver and the loose plug stuck to it and I was able to pull it out.
