Anybody had any luck with the TRG bushings?
So my squeaking saga continues. My mechanic and I have isolated the squeaking to the bushings on the TRG Sways. We tried to lube up the bushings and adjust the drop links to stop the problem. No luck. Has anyone had success with this issue using a bushing made from a different material? My sways are only about 6 months old so I think I have the newest iteration of the TRG bushings. Any help would be highly appreciated. I feel like I'm driving around in an awesome handling squeaky rocking chair
I've found that boat trailer axel grease works pretty good on the TRG bushings. Just make sure it's the bushings and not metal to metal from the collar agains the frame (I lube that too).
George
George
That lube Bob supplies is the stickiest, most tenacious stuff I have ever seen. I needed solvent to get it off my hands and tools. White lithium is not in the same league.
Greg H.
Greg H.
Greg H.
Greg H.
George
From: Lat: 47 Deg 26.848N Lon: 122 Deg 21.341W Seattle
I used lithium and have the same squeek...arg, it is horrible!
OTOH, it is not life threatening and we know what it is.
Viper Bob, can you give us a source for this magic goo?
If these are the same sway-bars I have, they came painted. Mine squeeked like mad. Take the paint off the bar at the place where the bushings hold the bar, so it's plastic against lubed steel. The squeek will disappear.
-Damon
'94 325i
'95 993
-Damon
'94 325i
'95 993
-Damon
'94 325i
'95 993
-Damon
'94 325i
'95 993
The lube that I have used for almost 20 years is teflon grease. It is great as it stays on FOREVER... (trust me. just wait until you try and get it off your hands). It is also essentially water proof so it does not wash off. ALso when lubbing a bushing, lube both sides of the bushing so that there is no squeek that can happen in between the clamp and the bushing....
BTW Alex, I sent your grease out to Yuri.....
