Camshaft Timing... (or how to gain 20 hp...)
#32
Mike J's rebuild writeup mentions the back-dating quite a bit.
http://www.pcarworkshop.com/index.ph..._timing_Part_I
#33
Accurate cam timing is important but I've done a lot of cam testing and I've never seen 20 HP from changing the cam position as much as 8 crank degrees with both single and dual overhead cam engines.
It sounds to me like in this example, advancing the cams - which is what you are doing by increasing the opening lift, is producing better throttle response which it should at low speed but it will also chop an equal amount of power from the top end in all the dyno work I've conducted. When you open the valve sooner it has to close sooner and that hurts top end power unless you are running a cam with excess duration. There simply is no free lunch.
Obviously with accurate engine dyno testing you could determine exactly what difference this cam timing change makes.
#34
I do, although even with the early cam sprockets it is still a royal pain to get the timing perfect due to the backlash in the design. From memory it is something like 2.5 degrees of play that the early system has with the pin in any one location, hence if like me you are trying to time the valves to within 0.25 degrees of each other you are in for a fight.
#35
In respect of advancing or retarding a 911 cam, because the relationship between the intake & exhaust lobes are fixed during manufacture in changing the timing you are actually altering all 4 valve events at the same time (IVO, IVC, EVO, EVC), whereas in an ideal world you would alter just one to determine what the engine needs. I hence have to totally agree with you that running any 911 cam set with 3 sub-optimal timing points does not help performance. I suppose the real secret is then knowing how to work out which one is right!
#36
It certainly ain't easy, right Mike?
#37
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I can relate to what Colin touches upon, slop in the pin bores etc. Once you think its spot on, you snug the bolt, recheck, all good, then final torque and its off !! Can be very frustrating indeed!!
#39
#40
To verify TDC, you can use a "piston stop" and degree wheel, or a digital read out one, like Colin uses.
I find this thread vey interesting and informative, and if possible would like to ask Colin to elaborate on his thoughts for the best procedure for cam timing, it seems you have a better way to get closest to optimum.
#41
So the OP is saying there is 20hp to gain from a stock engine with just timing? I don't buy it.
If it was badly off, sure. But I don't believe the factory timing could be so bad.
A couple of hp, maybe. 20...no way!
The method I have allways used (on BMW 6 cylinder engines) is to first accurately determine TDC with a gauge. Then find the valve open/close angles.
I think everything beyond that falls into the accuracy of the cam gear itself (play in chain etc.).
I have yet to time a boxer but I'm sure that day will come too...
![](http://m3supercar.1g.fi/kuvat/325E/IMG_2584.jpg/_smaller.jpg?rotation=1)
#43
I find this thread very interesting and informative, and if possible would like to ask Colin to elaborate on his thoughts for the best procedure for cam timing, it seems you have a better way to get closest to optimum.
#45
I think there is a little confusion here, you do not so much have the potential to gain 20bhp on a stock engine, but re discover the bhp that may be missing from a stock engine if the timing does slip for some reason.
