Help - how to disassemble front bumper?
Hi,
I did a search of the archives but couldn't find what I was looking for - probably too obvious (duh).
I am in the process of replacing the existing 'fog light + bumperette + amber signal' combo that is the stock look for a US 993 C2 with a 'MA Shaw turbo S duct + clear signal' combo.
I am taking off and hoping to patch the bumper as per John D's instructions.
I will have the ducts and RS splitters (also MA Shaw - yes, yes, yes, I heard all the warnings about slippery slopes ...), as well as the bumper painted - I had recently posted regarding paint shops in the SF Bay Area.
I used Robin's DIY to take the bumper off, but I am stuck at trying to get out the existing fog lights and bumperettes.
The furthest I got was to undo a metal retaining clip at the back, inboard side of the fog light assembly. I can NOT seem to get the fog light assembly to pop apart. What am I missing?
Also, how does one get the bumperettes out? Seems like I need a deep-well socket (what size?), but then the one I tried for size wouldn't even fit in the opening. How do others take the bumperettes off? It seems like there isn't a non-destructive way?
FWIW, I have learned from past experience (not on this car, luckily), that anything other than relatively gentle persuasion, especially when plastic is involved, usually yields disasterous (as in 'oh sh*t') results. Is it time to stop being overly cautious?
Many thanks in advance.
/alex
/alex
Duh,
now I feel really dumb - peered behind the bumperette and well ... there IS a screw that holds the fog light in place.
So now the only question is how to get the bumperettes off?
Thanks again
/alex
Thanks again
/alex
Ard
Bumperette should come off by prying plastic trim cover piece off (assume you already did) and using deep socket 8m i believe to remove two bolts holding bumperette on. I don't recall problem with fog light once bumperette is off. Seem to recall simply unscrew screws. Is bumperette covering any of fog light? Hope this helps. RK
Alright, I got the bumperettes off w/o damaging them (not that it matters, but that's my personal preference). 8mm deep well socket in case anyone cares.
/alex
/alex
Alex, I am in the process of the very same mod. Everything is still at Foreign West Autobody for paint.
Should be ready by Tuesday and I will begin the re-assembly. I will post pictures as I stumble though.
Originally Posted by CarmG993
Sorry to thread jack, but does anyone have a pn for the little black clips (drain ports) that are on the bottom of the bumper.
