Volk Racing TE37's on a 993 pic?
Keeper of the Truth
Originally Posted by KraZy007
Thanks Amir. As of this point i'm pretty much decided on a bronze set of TE37's for my car. Also would you happen to know if I had any chance of fitting 18x10 50mm offset in the rear of my narrowbody or should i just go with the 60mm offset 18x10? I'm trying to go for the most aggressive look possible, and i want the wheels as close to the fender as possible. I wouldn't mind rolling/pullling my fenders a bit to fit the 50mm offset wheels, but I'm wondering if it's even possible.
Originally Posted by Gelatomonster
IMHO you can fit the 10.5 TE37 to narrow body but you have to roll your fender
SIZE OFFSET HOLE P.C.D.
8 1/2J +50 5 130
10.0J +50, +60 5 130
10 1/2J +40 5 130
8 1/2J +50 5 130
10 1/2J +40 5 130
50mm or 60mm......is there no chance to fit 285's on the 50mm? What's the widest on the 50mm, 265?
What are you trying to accomplise? The Volks do not seem to have much of a dish anyways so I'm not sure how much diffence 1cm is going to make.
Originally Posted by David in LA
I have 285s on my 11" rims...ET50 will be very close with fender rolling - no 100% guarantee they will work. Also, not all 285s have the same width and profile..some are actually narrower than other brands' 265s.
I'm trying to get the rim as close to the fender as possible. Do you know your camber settings? I'll most likely go with a pirelli 285/30/18 tire, as pirelli tires have "rounded shoulders" if you will.
Yes, if nothing else, I would think these would make great track wheels. At the prices I've been seeing on the net, a set wouldn't cost that much... 2-2.5k?
