993 Forum 1995-1998
CE Light Off ?????
Old Jun 29, 2003 | 01:03 PM
Jeff's Avatar
Jeff
Thumbs up CE Light Off ?????
Knock on wood -- I've been battling the dreaded CE light for a month -- cost me $1500 so far. Based on recommendations from contributors on this site -- I'm 1/2 way through my second tank of gas with Techron and I'm running at 4K plus rpm's and the damn thing turned off. I can't believe it.
I thought for sure I would have to get it reset -- is that normal if whatever it was that turned it on, clears up, the CE light turns off??
Old Jun 29, 2003 | 01:21 PM
96P993's Avatar
96P993
Post
Not to be a happiness crasher but they will do that every once in awhile. Mine will go off for awhile then pop back up down the road. Have you checked the code (generic or otherwise) to see what it is telling you?
Old Jun 29, 2003 | 01:37 PM
Jeff's Avatar
Jeff
Post
I figured it was too good to be true. I've checked the code several times. cylinder misfires --- seem to vary relative to which cylinders. I'm fearful of a valve job as the only way out.
Old Jun 30, 2003 | 03:40 AM
Dave Crellin's Avatar
Dave Crellin
Post
If the CE light is triggered by the cylinder misfire, then you shouldn't be heading for the valve job. I had this error repeatedly after the having the valve job done (due to secondary air intake carbon).
Anyway, a new fuel injector cured it in every cylinder that the error came up on.
fyi, the othere errors were fixed by new distributor caps and a couple of new O2 sensors
Old Jun 30, 2003 | 07:17 AM
Jeff's Avatar
Jeff
Post
Dave -- thanks for the info. I've replaced my caps, wires and plugs. The 02 sensors were replaced about 6K miles ago. I have not looked into the fuel injectors -- is that a difficult/expensive repair?
Old Jun 30, 2003 | 09:57 AM
96P993's Avatar
96P993
Post
I would agree with Dave, I think the injector direction is the next one to take..If you can get the car onto a Hammer I believe they can turn each injector off to see which is bad...
Old Jun 30, 2003 | 01:26 PM
Dave Crellin
Post
I don't have the details on the price/time as these were done as part of a whole series of "bug-fixes". However the injector is in the region of $175 I think, and maybe one or two hours from a professional?
I agree about the HAmmer - it'll tell you which cylinder it's a problem with.
Old Jun 30, 2003 | 07:03 PM
Jeff's Avatar
Jeff
Post
Thanks for the info. Can not beat this site.
Old Jun 30, 2003 | 10:17 PM
96P993's Avatar
96P993
Post
Dave did your CEL just read one cylinder misfire or did it read several cylinders??
Old Jul 1, 2003 | 03:45 PM
Dave Crellin
Post
It read one cylinder - number 3. Then another cylinder, I forget which.
Anyway, I pulled the bill. The injector was $66 and the labor about 1.5 hrs
When the injector first failed, the car went from a rocket ship to a diesel tractor in about 10 seconds. It was virtually undriveable due to the misfiring. One the second, it was more of a slight hesitation around 2500 rpm when cold.
Old Jul 1, 2003 | 09:25 PM
96P993's Avatar
96P993
Post
Dave did you feel more of a hesitation when the car was cold??
Old Jul 2, 2003 | 01:53 PM
Dave Crellin
Post
Yes, it hesitated more when cold. Though the CE light came on when it was hot.
Old Jul 2, 2003 | 08:54 PM
96P993's Avatar
96P993
Post
Thanks Dave...I guess this is going to be my next avenue to go down...
