993 Forum 1995-1998
Shift Problem
Old Nov 13, 2002 | 02:17 PM
Henry's Avatar
Henry
Question Shift Problem
Recently, I have been experiencing a problem on some occasions when taking the car out of first or second gear, and into neutral...or while trying to downshift from second gear into first gear. The shifter does not move out smoothly, but sort of wants to stick in the original location and then pops out. I have made sure that the clutch pedal is depressed all of the way while shifting, but this still seems to happen. Does anyone know what the reason might be? I recently had the clutch slave cylinder replaced because it was going bad, but this did not help the sticking problem.
Thanks.
Old Nov 13, 2002 | 02:47 PM
tom_993's Avatar
tom_993
Post
This has come up a few times. I had the problem myself. I resolved it by tightening a loose transmission mount. You might check your transmission mounts and/or engine mounts. There are other things that can cause this, though.
Good Luck!
Tom
’95 993
Here’s one of several old threads on the subject:
<a href="http://forums.rennlist.com/forums/ultimatebb.php?ubb=get_topic&f=3&t=003773" target="_blank">Tough Shift OUT of Gear</a>
Old Nov 14, 2002 | 12:38 AM
dwe8922's Avatar
dwe8922
Post
I had the problem of corrosion on the input shaft. It allows the clutch disc to stay contacted to the flywheel even when you've pushed the pedal, and the pressure plate is released. Try blipping the throttle after pushing the clutch in. If doing that allows you to disengage the gear, you might have this problem. Do a search, as a couple of us talked this out in depth about a year ago.
David
