Owners Manual 95 vs 96 993 C4
what are the key fiferences bettween these manuals other than OBDII, I would rather get the 96 but I would settle for the 95.
All coments are apreciated, also if anyone has these Manuals Im interested in buying them.
Contact www.gmundbooks.com
You could also search the archives for more sources - this question has come up a few times.
I think the 1995 will probably be fine, but there are some diff's. (I think I had a late 1995 manual for my 1996). For example, I believe it tells you to use ATF for the power steering fluid, although Porsche put Pentosin in 1996 cars and recommended the switch to that. IIRC, you should not put ATF in a system that has Pentosin. I may be wrong on this issue, but it's something to look out for. P.s. can't a dealer get you a manual?
