Cab Boot fastener question
Noticed today that one of the fasteners( not the snaps) from my Cab boot is missing. Any idea where they can be purchased, other than the missing fastener the boot is in great condition.
thanks
thanks
Are you referring to the Tenax fasteners on the boot cover? Or the Tenax studs on the boot/conertible top?. Try <a href="http://www.worlduph.com" target="_blank">www.worlduph.com</a> or anyother convertible top vendor.
I've purchased the fastners from Part Werks of Chicago in the past. Their toll free number is 1-800-366-9147. They charge around $9.95 a piece plus shipping. I've seen them for less, but I can't remember where and Part Werks seems to keep them in stock. I have had a billing mix up with them once but they cheerfully fixed it once I contacted them.
Good luck.
Good luck.
Thanks for th sources of the fasteners ...... next question how the heck do you get them attached ???? are they sewn in ??? Any help is once again appreciated.
This board is great.......
The fasteners are two pieces and screw together, one from each side of the of the boot material. Very easy. If you look at the inside piece of the fastener you will see two small holes that are meant for a special tool to tighten it down but I used the tips of a needle nose plyers and that worked just fine.
