993 Forum 1995-1998
Straight pipes
Old Sep 11, 2001 | 01:09 AM
GratefulJED's Avatar
GratefulJED
Post Straight pipes
May I run straight pipes to my muffler bypassing the cats? Robin says my check engine light will come on and that I should not do it. Any thoughts out there? Thanks in advance.
Old Sep 11, 2001 | 03:29 AM
Kevin's Avatar
Kevin
Post
JD
Your 98 has four Ox sensors, two on the entry, one on each bank, and two after. By removing your cat, the OBDII cannot monitor your fuel mixture. You will get a check engine light. If you are looking for more HP, like most of us are, do a muffler change. You could also install a cup flywheel. Good luck
