993 Forum 1995-1998
Wheel diameter differences?
Old Dec 22, 2001 | 05:19 PM
993tt's Avatar
993tt
Post Wheel diameter differences?
I asked this in another thread but no one answered so I thought I'd give it another try.
I was wondering why Porsche put tires on a 200Mph (nearly, anyway car that differs in diameter from front to rear. I mean, isn't that exactly what they shouldn't have done!? The stress on the differential must be enormous when approaching 200! But then I (actually my brother helped me out) thought, Wouldn't the rear tire expand more, given the 60mm extra width, than the front when driving so fast!? Maybe it should be a 1.4% difference so that at higher speeds, when the stress is most, the wheels have basically the same diameter...
If this is true, then the difference of diameter should be less if the difference of witdh is smaller between front and rear...
thoughts people!?
Old Dec 27, 2001 | 05:00 PM
993tt's Avatar
993tt
Wink
Nobody answered this question yet??? Isn't there somone out there that knows about these things...
Please folks... at least, make a wild guess
Old Dec 30, 2001 | 08:19 PM
Jean-Marc's Avatar
Jean-Marc
Post
Not sure I understand your question but I'll tell you what I think.
First, in standard configs, the diameter of fronts and rears are nearly identical (e.g. D(225/40/18)= 637.2 mm and D(265/35/18)=642.7 mm) so 1/5 of an inch difference...
With regards to widths now: In RWD2WD cars, the job of the rears is to transmit power and therefore you want to have as much surface as possible to get that power to the ground. The job of the front wheels is to provide steering and up to a point, very thin tires can do that. Look at F1 cars to understand what I mean.
So, diameters are near even and Porsche did exactly what they needed to. One last thing, new P-cars understeer until you get passed a point and that is the safest thing for most drivers as when you understeer your "untrained" reaction when going too fast it to lift off. This brings the car back in line... So, for "driver x" the understeer is just what they need... Smaller front tires also contribute to that.
Hope this helps
JM
Old Dec 30, 2001 | 09:06 PM
ed devinney's Avatar
ed devinney
Post
Don't know about the 993TT, but I recall reading that the first series C4s ran different front and rear wheel diameters to bias the torque split front to rear. Could be nonsense, but since you're looking for guesses I thought I'd share!
Old Jan 1, 2002 | 10:31 AM
Jean-Marc's Avatar
Jean-Marc
Post
I owned a 964C4 and the fronts were 205/55/16 and the rears 225/50/16. Diameter of fronts is 631.9 mm smd rears 631.4 mm. In other words, identical (.5mm is 1/50") . just FYI
JM
Old Jan 1, 2002 | 01:58 PM
ed devinney
Post
Well there we are - another year, another myth put to rest :-)
