993 Forum 1995-1998
Check Engine Light Question
Old Dec 21, 2001 | 01:10 AM
Pete Lech's Avatar
Pete Lech
Lifetime Member
Question Check Engine Light Question
In an attempt to solve a occasional stumble in my idle (only occurs when the AC is off), I removed and cleaned the idle stabilizer. When I reassembled it, I had an obvious air leak so I took it off and put in back on again. After driving several miles, the CE light came on again. I had to drive another 20 or so miles before I could get back home.I removed the valve again, and discovered a crack in the rear hose under the clamp, which I sealed with black tape for now. Unfortunately, the CE light is still on. Do I have to go to a shop to have the light reset, or does this mean that I have still have some problem back there?
Old Dec 21, 2001 | 02:19 AM
Kevin's Avatar
Kevin
Post
Pete;
If you have solved you idle control problem I would disconnect your battery, and wait a few minutes and hook it up, it should cure your problem.
Old Dec 21, 2001 | 10:17 AM
Curtis - '97 Targa's Avatar
Curtis - '97 Targa
Post
Pete,
As an alternative to Kevin's approach, the CE light will reset itself after several driving cycles if no errors are detected. The only time a CE means anything really damaging is when it is flashing (that means that cat damage is likely).
I would just drive it normally for a couple of days to see if it goes out.
Also, if your car is OBD-2 ('96 and up) any OBD2 tool can reset the light. There are several discussed in older threads on this board.
