where's your 993? post yer pic...
hey... not sure, but maybe this can be fun.
where is your 993 right now?... or @ least in the last hr. or so... (hibernating or not, post a pic?) ... been raining here for days but not today... see my hood
i just filled up @ 3:30 pm.
cheers all & best2ya this new year.
(c'mon post a pic... i'm friggin' bored & not workin'2day!)
Last edited by 24FPS; 07-18-2010 at 02:49 AM. Reason: to re-add old pic to thread...
Yep.... Up in the air in mid-repair of the following:
- Lower valve cover gaskets
- SAI port cleaning
- SAI check valve replacement
- Spark Plugs
- Plug Wires
- Dist. Caps
- Dist Rotors.
Maybe I should have the wheels re-finished while its in the air..... Hmmmmmm.
Or, maybe I should pull the fan and shroud to have them powder coated..... Hmmmmm.
- SAI port cleaning
- Spark Plugs
- Plug Wires
- Dist. Caps
- Dist Rotors.
From: Lat: 47 Deg 26.848N Lon: 122 Deg 21.341W Seattle
A Garage Picture
So you can see a little crap kicked up from the front tires onto the rear fenders and if you peek through the spokes on the rims you can see the blue springs from the PSS9 suspension.
Also, for you old truck buffs, that is square (OK, rectangular but then it's truck stuff!) Peterbilt logo I had made from the original "lost tooling" when I worked there designin' trucks!
Maybe I will take it out on some sales calls tomorrow as it is clear and cold but it may snow Friday. I'll stay home if it does, Seattle is pathetic in the snow!
Cheers
Cheers
