Racing pedals or colored instruments??
#32
The gas pedal that is not adjustable should be ok, but the adjustable one was not good IMO for the track. See how in the pict. w/ the adjustable how it is level w/ the brake pedal? When you are hard, hard on the brakes it makes your foot inverted doing heel/toe and you can over-rev very easily. I set it back as far as it could go and still had that problem. ....which is why I went back to stock. I still have the rennline floor board and dead pedal though and they look cool (and don't interfere).
All IMO, but on the track I like the stock pedals. If you are doing heel/toe on the street you should be ok, but will be funky (bad) at the track w/ the adjustable, which is counterintuitive I know. I spent a bunch of $ on it so I tried to make it work!
